Radial replacement tires for Harbor Freight trailer?
Postby Krusty » Tue May 19, 2015 1:05 pm
I'm looking around now for some slightly larger radial tires to go on my harbor freight trailer. Anyone have some good sources for 4 bolt pattern wheels that'll hold a 13"-14" radial tire? I actually wouldn't mind finding some car wheels instead of trailer wheels (with the lug mounting surface further out to the side) as I upgraded the axle and put some brakes on it since I'm towing with such a small car.
Krusty
Re: Radial replacement tires for Harbor Freight trailer?
Postby bobhenry » Tue May 19, 2015 1:45 pm
THIS WILL KEEP YA BUSY FOR A WHILE............ :)
Bolt Circle Chart for tires "Mike's list":
http://tinyurl.com/2n4qrm
Printable Bolt Circle Chart for use when your searching for wheels:
http://www.teardroptrailers.us/images/bolt%20circle.jpg
http://tinyurl.com/3b3b9v = Thread
The bolt pattern for Tow V or bolt circle proper measuring methods.
http://www.tirerack.com/wheels/tech/tec ... ?techid=92
http://www.stagewest4x4.com/store2/stor ... attern.htm
http://www.sromagazine.com/shop/wheelguide.html
Vehicle Bolt Pattern & Offset Reference.
http://tinyurl.com/3j2tv
The bolt pattern for trailer tires thread.
http://tnttt.com/viewtopic.php?t=11850
Wheel and pictures of bolt patterns
https://www.rsracing.com/tech-wheel.html
How to measure wheel bolt patterns
http://www.randpcarriages.com/tech/boltpatternhtml.html
See more on Wheel bolt patterns and or Tire bolt patterns
http://tnttt.com/viewtopic.php?p=155689
Postby Krusty » Tue May 19, 2015 2:00 pm
Many of those links are now dead :-(
It looks like my first step will be to measure my lug spacing though. I'm mostly certain it's 4 on 4 but need to measure to find out.
Krusty
Postby Krusty » Tue May 19, 2015 4:11 pm
With enough googling I've confirmed the lugs are 4" apart. Alas, most 4 lug car wheels are 100mm (3.93") apart so it may be exceedingly difficult to find a 13" or 14" radial tire rim with an offset.
Oh well. it's probably for the better as I don't need to spend money on new tires right now.
Krusty
Postby Krusty » Tue May 19, 2015 4:48 pm
Well, here's something that could work, but adds extra cost:
http://www.ezaccessory.com/Wheel_Adapte ... -4100v.htm
http://adaptitusa.com/4x400to4x100wheeladapter.aspx
http://www.amazon.com/Wheel-Adapter-101 ... +4+lug+100
Combined with the fact that I found some 4x100 Mazda Miata wheels on craigslist just now for cheap, this might not be a horrible plan.
Krusty
Postby eggsalad » Wed May 20, 2015 2:07 am
etrailer.com has 13" 4x4" wheels for $25.
http://www.etrailer.com/Tires-and-Wheels/Americana/AM20222.html
You won't find much bigger than 13" in 4x4"
eggsalad
Postby bobhenry » Wed May 20, 2015 6:08 am
Krusty wrote:I'm looking around now for some slightly larger radial tires to go on my harbor freight trailer. Anyone have some good sources for 4 bolt pattern wheels that'll hold a 13"-14" radial tire? I actually wouldn't mind finding some car wheels instead of trailer wheels (with the lug mounting surface further out to the side) as I upgraded the axle and put some brakes on it since I'm towing with such a small car.
I forgot to add you can simply change out the hub for a 5 on 4 1/2 bolt pattern they are about $25.00 each and come with the bearings. Now the sky is the limit on options.
Postby dales133 » Wed May 20, 2015 6:10 am
I think English fords were 4x4
dales133
Postby Krusty » Wed May 20, 2015 10:43 am
I got an axle with brakes on it so I don't think I can change the hubs. It may be worth asking about however. Anyone know if I am able to replace the hubs on a Dexter axle with brakes?
eggsalad wrote:etrailer.com has 13" 4x4" wheels for $25.
http://www.etrailer.com/Merchant2/graph ... 2_1000.jpg
I think I did come across that in my searching. I was trying to dig my way down into finding some high offset car tires to bring the tires in a bit closer and cover the brakes though.
Krusty
Postby MtnDon » Wed May 20, 2015 1:16 pm
Changing the offset of a wheel changes the loading on the bearings. It is possible for that change to affect wheel bearing longevity. It may not happen for a long time, great number of miles, but that is a possibility. Just a heads up.
MtnDon
Images: 24
