Tire damage & separation
Postby noseoil » Fri May 25, 2018 11:14 am
We recently returned from a 10 day trip trip to northern New Mexico. We had stopped at the showers & I was just killing a little time, so since we would be leaving to return to Tucson the next morning, I decided to take a good look at the tires. I'm glad I did.
The driver's side tire looked ok from behind, but when I looked at it from the front, I saw a bit of bulging in the center of the tread section which I hadn't noticed when we left Tucson the week before. Basically, I put a straight edge across the center of the tread & eyeballed the amount of space at the edges. The space at the edges was much bigger at one point, but on the other side of the tire it looked fine & matched the opposite tire perfectly. Hmmm...
I was lucky enough to have stopped the trailer where the bulge was visible & it was obvious that there was a problem. These are 3 year old Goodyear Marathon 13" trailer tires (C rated only) and were supposed to be good ones when I bought them, but I've learned that they aren't as good as they should be. I store the trailer up on the jack stands, to take the load off the tires and keep them round if it sits for any amount of time. I always check tire pressure before towing, even on a short trip near town. They were balanced properly when mounted. I have covers to protect them from the sun here because it's so stinkin' hot in the summer. In short, I did as much to care for the tires as I could & to maintain them properly.
We finally got a chance to try the new brakes in a "panic stop" situation. As we crested a hill on I-25 in Albuquerque during rush hour, the semi tractor-trailer we were following slammed on its brakes, locked them up & came skidding to a stop. There were two highway vehicles doing some pick-up work in our lane & the lights didn't show up until the hill was crested & they were seen. Not sure what they were doing, but it was the first time I had to really stand on the brakes to stop quickly. I'm not sure I would have made it without the trailer brakes, or what would have happened if that tire was in place when I stomped on the brake pedal. I'm just glad everything worked as it did.
Here's what it looked like, not showing a problem.
154616
Look closely at the left edge of the tread, it's showing a separation between the road contact areas & the lower rubber. The gap is bigger, but you might not see it until it's too late. It's ready to come apart at higher speeds in the heat!
154618
Check those tires & don't just look at the air pressure. Take a bit of time & inspect them for wear, bulging & any bad signs!
137905
noseoil
Images: 670
Re: Tire damage & separation
Postby bdosborn » Fri May 25, 2018 1:19 pm
Goodyear Marathons are famous for failing often and catastrophically. Google "Marathon Tire Failure" and see how many hits you get. Both mine failed, one just like yours, here's a link:
Goodyear Tire Failure!
There's also lawsuits over Goodyear motor home tire failures (for a tire they knew would fail).
Motorhome Tire Failures
Images: 806
Postby noseoil » Mon May 28, 2018 6:45 am
Just a quick thanks to Discount Tire here in Tucson. They took one look at the tire & said it was bad & defective. Free replacement is on the way now since, I had the warranty & had taken good care of the tires. The bad one failed at about 16,000 miles, a bit over half the tread was worn off when it let go.
Wondering about a better 13" tire than the Marathon. Anyone have a suggestion for next time I buy a set? I'm going to build a utility trailer in the next few weeks & am thinking that a 15" truck tire like Tony Latham runs on his trailers would probably be the best choice at this point. I don't want to replace rims & fenders on the teardrop at this point, so a better 13" tire would be in order, if I can find one.
137905
noseoil
Images: 670
Postby coyote » Mon May 28, 2018 8:19 am
5th yr on road, 5th set of tires. Every dealer I've used, swears this is THE (13 inch) tire. I've given up. I just plan for a new set early every spring.
coyote
Titanium Donating Member
Postby Sparksalot » Mon May 28, 2018 10:33 am
Must be the camera angle, I'm not seeing what you are trying to highlight in the photos.
Sparksalot
Images: 687
Postby Homebrewer25 » Mon May 28, 2018 10:54 am
By rotating the images so they are aligned, I think you'll see the difference here:
before: 154640 and after: 154641
It's 5 o'clock somewhere ... time for a :beer:
Foam Ranger Build (postponed by COVID - resuming spring 2021): http://www.tnttt.com/viewtopic.php?f=50&t=70159
Homebrewer25
Images: 19
Postby Sparksalot » Mon May 28, 2018 11:03 am
Holy Carp! That's a problem Batman.
I had a set of tires on my tear for 10 years, the originals from Red Trailers. I just took them off because I was worried about the age of them, not the miles or treadwear.
Sparksalot
Images: 687
Postby dancam » Mon May 28, 2018 11:49 am
coyote wrote:5th yr on road, 5th set of tires. Every dealer I've used, swears this is THE (13 inch) tire. I've given up. I just plan for a new set early every spring.
Mind sharing which brands youve used? I just put a set of carlisle ultra crt on my trailer and they look great new! :) way better than the new bias plys the trailer came with... but im planning to leave on a 20k mile trip here next week
dancam
Postby S. Heisley » Mon May 28, 2018 6:32 pm
:o It looks like you were lucky to make it home, NoseOil!
As for me, I find that I need to replace my tires every 2 years, regardless of the brand. They simply wear out! I'm okay with that.
Postby noseoil » Tue May 29, 2018 7:56 am
Sharon, yes we were very lucky that the bad spot was turned the right way when we stopped & the sun was shining across the face of the tire. If the bulge had been at 6:00 or 12:00, it might have gone differently on the ride home as I wouldn't have seen a problem until it was too late. Can't believe these tires are out in the main stream & running all the time. Goodyear has a problem with their manufacturing if there's that much bad press out there on so many different vehicles.
By the way, weight for the empty trailer was right at 1660# (it's 5' X 9') for your spreadsheet, if you want to add us in there. Still, it shouldn't have been too bad of a load for the tires. Go figure...
137905
noseoil
Images: 670
