DIY trailer question
Postby Hubert » Wed Aug 02, 2023 3:18 pm
I am planning to build a trailer and have been working off the plans from Tony Latham's book. I will tow the trailer with a Subaru Outback and won't take it off road. The plan in the book uses a #9 Torflex axle with a 22.5 degree down starting angle. I am wondering if I would be better off with a 10 or even 0 degree starting angle for my use. The galley counter height in Tony's plan is 44" and I would very much like to reduce that by a few inches if I can. What would you recommend?
Hubert
Re: DIY trailer question
Postby steve cowan » Thu Aug 03, 2023 9:09 am
Used 1932 Ford wire rims and tire diameter was 29 inch.Wanted to keep height low and like you wasn't sure of start angle.Decided to use a torsion flexi ride adjustable axle.It has a splined arm that can be set at desired start angle.Not sure the angle I set,just what looked right,but would guess about 15 degree up.There are charts on internet to enter tire diameter to determine desired ride height versus start angle.
steve cowan
Images: 207
Postby Hubert » Thu Aug 03, 2023 11:44 am
Nice wheels! How high is your frame sitting off the ground? My main concern with lowering the trailer is scraping the rear end. I have searched the forum but most of the info I found was about moving the axle on top of the leaf springs on bolt together trailers and they seem to end up at the same deck height as Tony's plan (18").
I looked at the Flexiride documentation and they "strongly recommend the 24 degree down starting angle which provides the optimal ride. The other starting angles may be used under special circumstances." I have not seen any such caution in the Torflex literature I have looked at.
Dexter does not make it easy to buy a Torflex axle. When I click the Shop button on their website to get to the Axle Store, I cannot find any axles. The distributors near me don't have a way to order axles on their websites either. About the only place I found online is in Texas. Does anybody have a recommendation where to buy the Torflex axle, either on the web or in South Carolina?
Hubert
Postby swoody126 » Thu Aug 03, 2023 4:26 pm
Hubert wrote:I am planning to build a trailer
Hubert, IMHO it sounds like time to do some reverse engineering
¿ what do you envision being under the counter top ?
find that (whatever it is) and make sure you have allowed enuff room between the galley floor and the counter framing to accommodate it/them
add that dimension to the thickness of the floor and the counter top(incl framing) and you have where the top of your frame should be
THEN factor in your trailer framing materials and your chosen suspension IF YOU CAN
the last variable is the wheel/tire diameter
there charts on the interweb to help w/ tire dimensions
then you can factor in the wheel size
if it were me ... i'd do that math prior to ordering much of anything else
i think i see some compromise on your horizon
sw
swoody126
Postby Hubert » Thu Aug 03, 2023 6:14 pm
sw
Thank you, Swoody. I agree it's all a compromise. I have a good idea what I want to do on the inside of the galley and what height is needed for that. I am still looking to lower the counter height through exterior measures (tires and/or suspension). I guess my question is how much clearance I need under the frame. Do I need a whole lot more clearance than my Subaru has?
Hubert
Postby tony.latham » Fri Aug 04, 2023 10:45 am
Confession: My wife is the camp cook, not me.
But if you were to ask her, she's fine with the countertop height. Most of the actual cooking is done from the stove, which is about 40". If you were to ask her what she thinks of our galley, which is version 3.0 in our teardrop evolution, I'm confident she'd tell you she loves it.
The one thing you will give up on a different start angle is the departure clearance if pulling into a boondock spot that might be a bit rough. So a lot depends on where you'll camp. And speaking of that... boondock camps are often not level, and the countertop height varies greatly if you're parked on a bit of a slope.
There's an old thread on this issue that may help: https://www.tnttt.com/viewtopic.php?t=7214
I hope this helps,
Postby Hubert » Tue Aug 08, 2023 9:03 am
Thank you, Tony. I am still a bit torn, but leaning towards the 22.5 degree down start angle and only reducing the counter height a bit on the interior. I have to work out the details, probably wouldn't want to extend the counter into the cabin at a lower height.
Hubert
Postby tony.latham » Tue Aug 08, 2023 10:48 am
Keep in mind it will reduce the foot clearance inside since the countertop extends into the cabin and becomes the lower shelf.
Now... you could build it so the countertop/bottom shelf are two separate pieces and the rear bulkhead is one-piece. Without spending all night thinking about it, I think it would work without causing grief in some other direction.
You will lose storage space in the galley, particularly above the cooler and we find that drawer handy for silverware and all sorts of miscellaneous stuff.
I have not heard anyone that used my book complain about the countertop height. :thinking:
You might ask Ralph B. aka Western Traveler for a second opinion: https://www.tnttt.com/viewtopic.php?f=50&t=73777
He's used his sweet camper a lot.
Postby Hubert » Tue Aug 08, 2023 12:03 pm
tony.latham wrote:Image
I might have had my measurements wrong. I think I measured 23.5" from the floor to the top of the counter in the CAD file. The drawing you posted shows 22" to the floor, which is already a bit lower. With the floor thickness and the deck at 18" the counter would be either at 41.25" or 42.75". I'm pretty sure the book says the galley counter height is at 44". I have a counter that is right at 42" and while it is workable, it is a bit high so I avoid it for food prep. I'll take another look at the drawings tonight.
I have convinced myself that I do not want to lower the suspension because that also reduces the head room below the hatch, so I'll order the axle with the 22.5 degree down start angle and worry about the counter height later.
Hubert
Postby tony.latham » Tue Aug 08, 2023 12:06 pm
I have convinced myself...
And I've convinced myself you are doing the proper amount of reasoning or thinking-through.
:thinking:
Postby Tom&Shelly » Tue Aug 08, 2023 12:22 pm
tony.latham wrote:we find that drawer handy for silverware and all sorts of miscellaneous stuff.
I'll second that. We have a single drawer, that is a little larger than half of Tony's. After every long trip we try and prune down what we have in there, but that drawer is always over-filled. Wish we had room for one or two more.
Our teardrop is a slightly different design and, fwiw, we have a single bulkhead between the galley and cabin from floor to ceiling. Turned out to be structurally good design. It's right where the transition occurs between one 3/4" core and another in our walls, and so reinforces that slightly weak spot.
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2025
Postby Hubert » Wed Aug 09, 2023 6:01 pm
I double-checked the CAD file and the top of the counter is at 23.5" from the floor, so 42.75" to the ground. The book says counter height is at 44". I guess it's somewhere in between depending how much the camper is loaded. I'll make a drawing of my galley layout when I find some time and keep drawers in mind.
I talked to a Dexter distributor near me today, and he strongly recommended not to reduce the load capacity because you won't notice any difference if you're underloaded, but you will if you're overloaded, and you never know what you might want to haul... In a different thread, somebody recently posted a link to wandertears campers, and I guess they are of the same mind and put a 3,500lb Torflex axle on a 1,300lb camper. Any thoughts?
Hubert
Postby tony.latham » Wed Aug 09, 2023 7:16 pm
That axle guy is spot on for a utility trailer but not for a teardrop. If you follow my plans, it'll weigh at a touch over 1,300 pounds. Throw water, cooler, and a battery in, and that's what it'll haul trip after trip--you do know what it will haul. That's why I suggest an axle designed for 1600 pounds.
That 1300-pound Wandertears with a 3,500-pound axle is going to bounce like an empty dump truck. :thumbdown:
Postby twisted lines » Wed Aug 09, 2023 7:58 pm
Hubert wrote:put a 3,500lb Torflex axle on a 1,300lb camper. Any thoughts?
In my (P,OP) Poor start right there!
Racking up; And Rapin foam
twisted lines
Postby Hubert » Thu Aug 10, 2023 1:49 pm
tony.latham wrote:That axle guy is spot on for a utility trailer but not for a teardrop. If you follow my plans, it'll weigh at a touch over 1,300 pounds. Throw water, cooler, and a battery in, and that's what it'll haul trip after trip--you do know what it will haul. That's why I suggest an axle designed for 1600 pounds.
I figured his expertise is more with utility trailers than with campers.
I ran your trailer design through the tongue weight calculator spreadsheet for the braked road option, and it looks like the braces are limiting the maximum weight to around 1,700 pounds anyway, so it makes little sense to spec the axle any higher than that. I'll have to pay close attention to the weight while I'm building.
Hubert
