Clearance question for my trailer build
Postby italianub » Wed Dec 06, 2023 5:04 pm
I tried doing some searching and came up a little more confused. To be clear, I am not an automotive guy so forgive me if this question seems elementary.
How can you determine how high up your trailer frame is from the ground? I know there are lift kits to raise it, but if you build a trailer frame and put a leaf spring axle on it, is it purely the tire size that will determine the distance between the ground and the frame? What are ways to lower or raise it?
Thanks for any info you guys can provide, this forum has made me so much more confident in my upcoming build. While I am sure I'll have more questions come 2024 when I begin, this is an area that I am very unfamiliar with.
Build began Feb 10th, 2024
Build journal: viewtopic.php?f=50&t=76227
Video build journal: https://www.youtube.com/playlist?list=P ... 0ZP7TwtcT3
italianub
Re: Clearance question for my trailer build
Postby Pmullen503 » Wed Dec 06, 2023 5:36 pm
Ground clearance is basically half the tire diameter if you use leaf springs. The axle will always be the lowest part no matter how high the frame is.
If the goal is to get the frame higher (so the frame won't scrape turning into a steep driveway for example), you could add taller leaf spring mounts.
If what you want is ground clearance for off road travel, then you want half axle type suspension.
Pmullen503
Images: 67
Postby italianub » Wed Dec 06, 2023 6:58 pm
Pmullen503 wrote:Ground clearance is basically half the tire diameter if you use leaf springs. The axle will always be the lowest part no matter how high the frame is.
Thanks for this info! So for example, if I am using 265/70R16 tires on my truck, this means the tire has a height of 2.75 inches and rims are 16 inches, so the clearance would be half of 19.75 inches (9.875 inches). Does that sound right?
Seems pretty low, so maybe I should get the trailer leaf spring mounts to raise it up. As you can see in this photo, my truck's hitch starts at about 14.5 inches from the ground, center is around 16 inches (not lifted), so I would imagine I should bring the trailer up a little. But how much?
italianub
Postby TimC » Wed Dec 06, 2023 7:07 pm
One method many of us have used is to mount the axle over the springs rather than under the springs. I'm no expert on the matter but I was advised to install larger, stronger U-bolts instead of using the ones included with the kit trailers I have purchased. Installing over the springs will effectively lower the trailer bed by a few inches. Note: some axles will not allow for this method but may be modified.
Tim
Niagara, WI
TimC
Images: 751
Postby QueticoBill » Wed Dec 06, 2023 7:25 pm
Your 9 or so inches to axel is more clearance than my Outback. I don't think you need to raise it more. I have 12" tires and underslung the axel as Tim suggested, and no problem.
The hitch just requires the right ball mount for a level frame.
QB
QueticoBill
Images: 22
Postby Pmullen503 » Wed Dec 06, 2023 7:45 pm
For aerodynamics and stability it's generally better to keep the trailer frame as low as practical. If you need off road ground clearance use taller tires and half axles. You can get a drop hitch mount to match the truck receiver and trailer height. You want the frame to be more or less level while towing.
Pmullen503
Images: 67
Postby Sparksalot » Wed Dec 06, 2023 8:27 pm
Larger tires and flipping the axle relative to the springs can do wonders. For my tear, the combination of the two gave 5” of change to the ride height.
Before with 25” tall tires.
172098
Before with 27” tires.
172458
After with 27” tires.
172461
172797
Axle before and after flipping.
172459
172460
Sparksalot
Images: 687
Postby italianub » Wed Dec 06, 2023 8:55 pm
Thanks everyone! I understand things much better now :)
italianub
Postby Onajourney » Thu Dec 07, 2023 10:19 am
I you want the most true clearance, go with axless torsion axels.
Onajourney
Images: 181
Postby Squigie » Thu Dec 07, 2023 10:36 am
The axle manufacturer should have spec sheets for their products.
You can use those dimensions and tire diameter to estimate ground clearance and frame height.
With Timbren axle-less suspension and ~26" tall tires, I believe I am at 19.75" for frame height. Should work well with my truck and other models in the class. Slight nose-down angle to the trailer frame with ~300 lb of gear slightly squatting the truck.
Squigie
