Drilling a new hole through metal
Postby S. Heisley » Fri Feb 28, 2025 10:58 am
Saw this and thought it might be helpful to some of us:
https://www.familyhandyman.com/list/tip ... VQpEU1uwtg
Re: Drilling a new hole through metal
Postby TimC » Fri Feb 28, 2025 7:42 pm
Thanks for that Sharon. I've been drilling metal for years and learned quite a bit from that article.
Tim
Niagara, WI
TimC
Images: 751
Postby tomhawk » Sun Mar 30, 2025 7:09 pm
I have found drilling holes in metal to be one of my least favorite tasks. This article covers many important concepts.
One problem I have had is that the drill bits get dull after some number of holes. Using a dull drill is most unpleasant.
There are different grades of drill available. Some retain cutting better than others. I don't think this is completely obvious when you buy them.
for example I noticed that Harbor freight has two brands. The Bauer brand costs about twice what the Warrior brand does. I had been sticking with the cheaper version but I bought a batch of Bauer drills. These were remarkably better. Definitely worth the price difference. Based on all the advertising I would never have guessed.
Do folks have some recommendations of better drills? I feel pretty ignorant about this.
I have seen various methods of sharpening dull drills. Is that something folks have opinions about?
Thanks,
Evolution is driven by mistakes, not plans.
My build: https://www.tnttt.com/viewtopic.php?f=55&t=75248
tomhawk
Images: 104
Postby Tom&Shelly » Sun Mar 30, 2025 9:10 pm
I keep a separate set of numbered bits for drilling though metal, only, with the drill press, only, and cutting fluid (oil). Took a couple of tries to explain to Shelly these bits are not for drilling in wood. She seemed to have trouble understanding wood dulls the bits--think she thought I said that backwards--and saw-dust holds moisture which helps ruin the bits. Finally, I showed her what that set of bits cost to get her attention. (Don't tell her I told you about this!) :shhh:
The last time I had to drill in steel was when I hung peg-board on our garage walls last month
174322 174321
Can't use a drill press for that, and I didn't want any cutting fluid soaking into the board. The solution was to use a cheap brand new jobber bit, which I threw away at the end of the project.
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
