asianflava wrote:Most people say that the larger tire, with the larger circumference, turns slower which prevents the bearings from overheating.
I always wonder about the wheel bearing issue. True the smaller tires will cause the bearing to turn more revs, but how many miles do you go before you grease up. I've run my cars well over 50,000 mi without greasing the bearings and I'm curious as to why the bearing on the trailer will be any more of a problem. I remember Roly's post on his Minden trip traveling at 70-75 mph, he didn't notice any over heating of the (12") wheel bearings ( just some tire wear issues). If I'm thinking right, my wheel bearings on the trailer carry half of the trailer weight (500lbs), but the car wheel bearings carry about 1/4 of the weight of the car (750lbs). They might be a little bigger on the car, but why all the worry about the tralier bearings. What am I missing?
Any problems with bearings over heating?
I've put on about 10,000 mi on the teardrop (with 15" wheels) and don't see any need to re-grease. Four or five years from now I might grease up and I have "EZ-Lub Dexters in case I do.
So I'm ready. What do you guys think about this?
