Hubs, Wheel bearings, axel, brakes
Postby Ron Dickey » Sat May 27, 2006 3:43 pm
I have no experience at this ... Luckly I have a neighbor who does.
I found this site and at bottom it show how to put the bearings on the hub.
http://www.championtrailers.com/techsup.html
The nut on the outside I guess only goes as far as the hole in the end of the axle? :oops: Right??
Ron D.
173882......173887
Ron Dickey
Images: 787
Postby Miriam C. » Sat May 27, 2006 4:05 pm
Ron,
I hope I have this pictured in my mind right. The hole at the end of the spindle (axle) should have a cotter pin in it to hold the bolt on. Hope that helps.
Miriam
Postby angib » Sat May 27, 2006 4:59 pm
Ron,
You want to follow the instructions in the section headed: 'D: PRE-LOAD BEARINGS'
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Arne » Sat May 27, 2006 6:23 pm
that is a good write-up on bearings...
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
