drop floor dinette
drop floor dinette
Postby KA » Fri Jun 30, 2006 10:47 am
Hi,
I'm planning my chassis with a drop floor dinette. I'm assuming that the table should be centered in the door. I plan to have 2 doors so the table will be free-standing. I'm assuming that hanging the table on a closed door would not work very well because of stress to the door. My trailer will be a 5 X 8 Benroy style. My question is, what dimensions would work best for my drop floor box? I want to figure out where to put the cross pieces on the chassis. I also plan to have a front box on the trailer. I'm not sure what tongue length yet.
Any suggestions?
Thanks! :designing:
KA
Images: 9
Postby mikeschn » Fri Jun 30, 2006 4:54 pm
KA,
I'll run outside and take some pictures and give you some measurements of my dropped floor.
We have company, so I'll probably post that on Sunday.
drop floor dinette
Postby KA » Fri Jun 30, 2006 5:34 pm
Thanks Mike!
:D 8) :applause:
Kris
KA
Images: 9
Postby grant whipp » Fri Jun 30, 2006 9:08 pm
KA!
You didn't say whether your dinette will seat two side-by-side or four in facing pairs. I've found in my trailers that a 24" front-to-back measurement is just about right for two side-by-side and 30" is comfortable-but-cozy in the facing pair arrangement. Width should be just inside the frame rails, but with enough clearance to get an extended caulking gun tip up to seal the joint there. Depth is up to you and your desired ground clearance - my pans extend below the bottom of the floor 6-1/4"
Good Luck, and ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
drop floor dinette
Postby KA » Fri Jun 30, 2006 10:43 pm
Thanks Grant! That info is really helpful. I think I want to try to make a dinette for 4 people, although it will ususally only seat 2.
Kris :thinking: :)
KA
Images: 9
