purplepickup wrote:Steve how did you apply the epoxy? I can see an even texture in the photo. Do you use a foam roller?
'Zactly!!! I just roll it on! After the 'glass is on, I'll do a couple of fill-coats in the same manner. I'll scrape the coats in between with a cabinet scraper to remove any bumps.(sanding "green" epoxy is a strict no-no!!)These coats fill the weave in the cloth, and give a build up of material for finish sanding, after the epoxy is fully cured.
