Trim sources and sealing
Important Information and Stickies...
(Threads with essential information about building teardrops)
Postby jamorgan3777 » Tue Dec 08, 2020 4:21 pm
Hello,
Can anyone direct me to a good source for edge trim and what the best method is to seal under it? Butyl tape or a certain type of caulking? I would like something I can trim flush with the edge.
My plan for exterior treatment is as follows:
1) Baltic Birch Plywood skin
2) "The Mix" to waterproof it
3) Monstaliner rolled on over the scuffed (220 grit) poly surface
Anyone have any cautions for this plan? The trim I am thinking will for sure go around the bottom of the trailer where the sidewall meets the floor. I did the "overlap" method where theoutside skin extends down to the bottom edge of the floor (where it meets the trailer frame). This seam is what I was thinking would be best covered by some L channel with caulking or butyl tape on both side (legs). I am also considering edge trim on the top and sides of the cabin, but might just do a round over and have no trim.
Any help would be appreciated.
jamorgan3777
Re: Trim sources and sealing
Postby dmdc411 » Tue Dec 08, 2020 8:30 pm
For trim, I'm fortunate to live near a warehouse for Bell Industries. Its been 6 years since I bought from my local RV shop. Being close, was able buy trim in 12(?)ft lengths. Heres the catalog I have from 2013Image
Sent from my SM-G970U using Tapatalk
dmdc411
Postby KCStudly » Fri Jul 15, 2022 3:57 pm
IIRC there have been several members here who have had trouble with using bed liner products directly over unreinforced plywood. Neither the Mix, nor bed liner have tensile strength, and the plywood will still move and shift with weather, resulting in cracks and water intrusion.
Better option to mix is to apply fiberglass weave and epoxy (over wood polyester resin would be "okay", too... but not over blue or pink foam board, the MEK hardener in polyester resin eats polystyrene foam).
Epoxy alone has the same problem as bed liner. You need the glass strands to provide tensile strength and prevent cracking.
Once you glass, if you still want the added expense and texture of bed liner, go for it!
Postby tony.latham » Fri Jul 15, 2022 6:43 pm
As KC mentioned, using a bedliner over bare or primed wood (including the "mix") is quite possibly a recipe for disaster. Fiberglass/epoxy is an easy thing to do and will prevent the plywood from checking. It'll cost about $250 at the most.
Take a look here:
https://www.tnttt.com/viewtopic.php?f=21&t=71357&p=1244097&hilit=+checking#p1244097
:thinking:
Postby twisted lines » Fri Jul 15, 2022 8:08 pm
Old post anyone done it? :lol:
Racking up; And Rapin foam
twisted lines
Postby KCStudly » Sat Jul 16, 2022 11:19 am
See Tony's video immediately above.
Return to Essential Information about building teardrops
