How To Best Attach 1/8 “ Bendable Plywood
Important Information and Stickies...
(Threads with essential information about building teardrops)
Postby teardroptv » Fri Apr 08, 2022 3:07 pm
What is the best way to secure 1/8” bendable plywood to the spars? Should I use wood glue and a staple gun or wood screws. I would be very grateful for some guidance. Thank you in advance for your assistance.
teardroptv
Re: How To Best Attach 1/8 “ Bendable Plywood
Postby Woodbutcher » Fri Apr 08, 2022 6:32 pm
It sort of depends how you are finishing over the wood. If it's getting covered with aluminum or something else, I always used a liquid nails glue and 5/8" coated staples. I always use 2 layers of 1/8th inch and stagger the seams over the first layer. I know some say one layer is enough, but for the little extra weight and expense I want a little extra security from a falling branch.
Woodbutcher
Postby tony.latham » Fri Apr 08, 2022 8:01 pm
I use PL Premium adhesive and 1/4" crown staples. But that's for 1/8" Baltic over foam board too.
Postby halfdome, Danny » Fri Apr 08, 2022 8:51 pm
I agree with Woodbutcher on 2 layers of 1/8" plywood over lapping the first layer joints using staples.
I use Tightbond II and use a Bondo spreader to spread the glue in between layers.
I have actually stood on the roof of some of my teardrops.
It's like having a pre formed piece of 1/4" plywood for the roof, very strong.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Graniterich » Sat Apr 09, 2022 9:53 pm
Pl. 3x adhesive, no mechanical devices used
Sent from my KFTRWI using Tapatalk
Graniterich
Postby Bruce R Leech » Thu Jul 13, 2023 3:54 pm
tony.latham wrote:I use PL Premium adhesive and 1/4" crown staples. But that's for 1/8" Baltic over foam board too.
thanks for the nice video Tony very clear
Bruce R Leech
Postby nbcarey » Fri Aug 04, 2023 9:48 pm
You could do a lot worse than to use a good marine epoxy and fasten it with Raptor nails or staples — a nylon fiberglass composite. Once the epoxy has cured, the nails add no significant strength — they're there mostly to apply clamping pressure.
But, they can be cut with a saw or chisel, or sanded. They don't corrode. They're not susceptible to electrolysis. So, no need to remove the fasteners.
Popular for cold-molding boat hulls — what you're essentially doing with a teardrop and multiple layers of thin ply.
The drawback is they require a specialty pneumatic nail- or staple-gun.
https://raptornails.com/product-applica ... ilding.php
nbcarey
Return to Essential Information about building teardrops
