TD behind a Samurai???
Moderator: Sonetpro
Postby bobhenry » Tue Mar 04, 2008 1:32 pm
brian_bp wrote:
bobhenry wrote:http://www.microcarmuseum.com/tour/bmw600.html
I think this is the model but a different year. Note the wider rear stance than the Isetta.
According to various sources, the 600 is the bigger, later, and much less successful model... yes, it has a more conventional rear track, but basically the same front as the 300. Still a lousy tow vehicle!
That's what made the picture funny !!!
Postby bobhenry » Tue Mar 04, 2008 1:42 pm
I've got one of these, a 2000 Suzuki Esteem 1600 cc 5 speed.
I put it on almost every work day and wear it to work. It is a great little car and the 45+ MPG is fantastic. I would love to find a hitch for it but they arn't available. While it may not like my 5x10 I know it would whiz around with Eggbert my motorcycle tear. It would be like having an extra trunk.
Postby brian_bp » Tue Mar 04, 2008 1:42 pm
Oh, I got that... these micro-rigs always make me smile. I think that the 300 is even better in that way, since the 600 is almost a real car.
brian_bp
Images: 9
Postby schaney » Wed Mar 05, 2008 7:16 pm
Philip, as noted by Jagular7 an Explorer Box might work for you.
At 400 lbs dry my Geo Tracker easily pulls it. Once I get the 4:1 low range gears in it, towing it deep into the woods will be no problem.
On the subject of morning coffee, I have that covered :D With your stove on your cooler on the front rack. Just reach out the window for coffee in bed :worship:
Scott
Camping the "Compact Way"
schaney
Images: 262
Postby SlyTerry » Tue Nov 11, 2008 5:40 pm
:lol:
SlyTerry
Images: 21
Postby Wolffarmer » Thu Nov 13, 2008 7:25 pm
Phillip
I have a 94 sidekick, manual tranny. I pull my TD with it. I am not sure the weight but guess about 875 pounds. It does stick up tall but i have lots of ground clearance, even for the rather deep footwell. I can tow it pretty good on the highway, about 65. If you build lighter and a bit shorter and keep off the very fast roads when ever possible. (which is why we have 4x4 and trailers made for off/rough roads, right) You should be ok. Or get yourself a 1600 cc motor and jam it in there. Oh, i made my tongue as short as possible to keep it in the wind shadow as much as possible.
Wolffarmer
Images: 309
Postby wolfcri » Wed Apr 15, 2009 1:10 am
wolfcri
