ChefConroy wrote:Also a newbie in the PNW, venturing into building my own and facing the same concerns.
Aluminum would be balls-effing expensive, unless I'm missing a source. Have a look at marine-grade plywood. Most lumber yards carry it. Crosscuts in Seattle has a fantastic selection. Bare in mind, this stuff is in the range of $150 a sheet. But it'll get the job done.
I ended up going a different route, because I'm doing a 6'6" wide Kampmaster; so I'm joining two sheets of ply to form the base. I found some lovely 1" thick 4x8 sheets of Douglas Fir plywood at Ballard Reuse for $20 a pop. So I had to make sure it would be protected from the PNW elements! Thankfully, I found this stuff which will protect against moisture, bugs, mold/rot, etc: http://www.amazon.com/Green-Products-210-328-Preservative-Copper/dp/B003VKK44I/ref=sr_1_4?s=hi&ie=UTF8&qid=1446485597&sr=1-4&keywords=copper+green+brown+wood+preservative
So, I applied that per the instructions on the label, added a coat of Rustoleum Automotive Primer (I'm restoring an old camper chassis as the base to my project, so I had some kicking around), and finished off with a coat of Rustoleum spray-on truck bed liner (probably going to add another coat or two) to act as a rock and debris guard.
But if you just need a single 4x8 of ply, I'd just go the marine ply route.
