Newbie from Texas, starting the angular soon
Postby Jfox1095 » Wed Jul 06, 2016 4:15 am
Hey guys,
I'm a young guy, and I'm about to start my first build. The first trip I plan on taking with it will be in September up to BC, Canada. I've already started designing, and plan on starting to buy materials very soon. I chose to go with an angular design over a straditional curve because I find them slightly more appealing as I drive an old jeep(boxy by design), which I plan on pulling it with. My plan is to build on a 4'x8' base, and have the entire build insulated(floor, walls, and ceiling). I've attached a quick pick of my plans. If you have any comments, or suggestions they would be greatly appreciated. Especially concerning the hatch.
Jfox1095
Re: Newbie from Texas, starting the angular soon
Postby greygoos » Fri Jul 08, 2016 8:52 pm
Good luck with the build
greygoos
Postby p moore » Sat Jul 09, 2016 10:16 pm
I like that. Can't wait to see it develop. Oh, and welcome.
Paul
p moore
Postby AZ_Desert_Rat » Sun Jul 10, 2016 11:31 am
Hi Jfox1095,
Welcome to the Forum... I like your basic idea and am watching to see it come together... :pictures:
Hey BTW, Sept. is just around the corner, were you talking about Sept., 2016... That's awful tight schedule... :NC
Good luck and keep us posted... :pictures: :pictures: :thumbsup: :thumbsup:
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Postby bc toys » Mon Jul 11, 2016 7:35 am
welcome to site let us know a little about you like name, where you from Tx is big and there are many trailers all over that state If you can go look at some at a gathering everyone is willing to tell you how they did things to their trailers
bc toys
Images: 42
Postby Jfox1095 » Sat Jul 16, 2016 7:35 pm
Started on the build today. Bought a 48x96(which actually measures 48 3/8" x 96 1/8") folding trailer form harbor freight.
I started by taking the two halves of each side, grinding he paint off and welding them together.
After which I cleaned up the welds and repainted.
After it was simply just bolting the trailer together per the instructions. Minus a few pieces of hardware that are no longer usable since it no longer folds.
Monday I plan on getting it registered and using it to start collecting materials.
Jfox1095
Postby lrrowe » Sun Jul 17, 2016 7:51 am
Does anyone know why on posts such as above, why the printed section is so small and the photos are so big...at least for me? The print is so small, I cannot read it and therefore pass on what might be a great thread.
Bob
lrrowe
Images: 439
Postby Jfox1095 » Sat Aug 13, 2016 12:06 am
Finally got my build going today. Got my floor and the start for the walls framed out. Meant to take more pics but realized after I stopped that I forgot to.
Jfox1095
Postby Jfox1095 » Sat Aug 13, 2016 11:13 am
Writing up what I did last night.
Started with 2 sheets of 1/2 plywood, and 3 12' 2x4s. First I laid out my base board of plywood and drilled my holes to match the ones on the trailer. After that I framed the outside of the board with the 2x4 leaving myself enough overhang to set my walls on. Then I secured and drilled the holes through my 2x4s. Using 3/8" bolts and t-nuts(that way I don't have to worry about backing up a nut) I secured the base to the trailer. After that I cut out the foamboard insulation I bought to fit the base, and used the other 1/2" plywood board to close everything up.
Once I get the walls, doors, window, and vents up, then I plan to seal everything with fasco 110 epoxy. It's an epoxy with a consistency very similar to Vaseline. Once that seals and cures I plan to paint
Jfox1095
