Greetings
Greetings
Postby hdeluna » Thu Apr 02, 2009 9:41 pm
I saw several teardrop trailers at a campground near Austin, Tx. I decided I had to build one. I'm a teacher. So I research everything. I found out second that my little Ford Focus handbook says no recreational towing.
Has anyone any math about why I can't tow with my Ford, or will I pull off the rear end, bumper, or cut the car in half. U-haul had no problem putting on a hitch rated for 1500lbs/200lbs for the tongue. My car capacity is 870lbs for passengers.
Has anyone used excurted aluminum to build frames? Any help or direction would be appreciated. I know I have to keep it ultralight.
Best wishes,
Hector de Luna
Producer/Director
PS My first job is doing documentary work...formerly PBS, :thinking: now independent.
hdeluna
Postby bg » Fri Apr 03, 2009 1:06 am
The general opinion is add a transmission cooler and stay out of overdrive if your transmission starts to wander.
There are at least a dozen teardrops in the DFW area. A handful of us will be down at Purtis Creek State Park on the weekend of the 17th.
Bobby(, Kim & Wayne)
bg
Postby Roly Nelson » Fri Apr 03, 2009 3:17 am
Welcome to the forum, Hector. There should be no problem towing a light weight teardrop trailer with your car. I am sure you can purchase a do-it-your-self bolt-on trailer hitch on your Ford Focus. Tears are being towed by tiny Volkswagons, Nash Metropolitans, all sorts of Mini's and I have no problem at all pulling my 500 lb woody with my 4 banger Camry. Just tow with no overdrive in the hills and perhaps you might think about a trany cooler, just to be safe. Good luck.
Roly 8)
Roly Nelson
L'il Ol' Woody Builder
Postby Miriam C. » Sat Apr 04, 2009 4:17 pm
Image to the playground Hector.
I won't tow with my Nissan Sentra because it is too small to stop or pass with a lot of weight. It has a 1.6 liter motor. If you can put your air condition on, fill the car with weight and the gas tank and still pass or stop without a noticeable difference you might get away with towing a light TD.
You can always add brakes .......... With Sentra the tow weight is 1000 pounds but you can't really get away with it.
Postby greg755 » Sat Apr 04, 2009 4:23 pm
Welcome,
i have an 08 Ford Focus and tow the tear just fine, as long as they are under 1000 pounds.
When I pull the other trailers (1200 pounds and up) I can feel them.
My suggestion: Take off the overdrive and install electric breaks if possible.
I don't have a tranny cooler, but it wouldn't hurt, they are cheap and fairly easy to install...
"It is a cruel thought, that, when we feel ourselves standing on the firmest ground in every respect, the cursed arts of our secret enemies, combining with other causes, should effect, by depreciating our money, what the open arms of a powerful enemy could not." --Thomas Jefferson to Richard Henry Lee, 1779. ME 4:298, Papers 2:298
greg755
Grand Poobah
Images: 65
