Questions from a newbie.
Postby ebonbetta » Fri Aug 27, 2010 12:03 pm
Hello My name is Jim Gilmore. Up until last month I was using a 1982 lazy daze to live in and hunt for gold in the california desert. But my rv did not pass smog. I am considering switching to a trailer of some kind. While I can do with out many options, I'd like a indoor potty,a bed and a little room for my drywasher which folds up and a few buckets. I presently have a honda civic wagon/van. Which while small does afford me some room for the toys.
I am curious if anybody has built a tear with the back end able to be swung open.
I'd also like to know if anyone has raised the floor about 8" above the trailer frame to allow for under floor storage from side to side. I'd like ac but never had it before. So I can survive without it. A little roof space for a solar panel or two ,and I'd be good to go. I've existed with a 1200 watt gen for over a year. Which is enough to run a portable ice maker.
My biggest problem will be finding a location to do the build. Perhaps in a rented storage space.
Then the question is can it be built light enough to be pulled by the honda.
ebonbetta
Postby Cliffmeister2000 » Fri Aug 27, 2010 7:12 pm
You have some very tight requirements, but I'll bet they can be met. :thumbsup:
The air conditioner will take a bigger generator. Under floor storage has been done before.
A weekender without a galley might be a good option for you. If you skip the galley, that will reduce the weight quite a bit!
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby Tadlan » Sat Aug 28, 2010 11:36 am
Hi. I'm a newbie myself, but I did just post on another thread my plans to do some experiments with a chiller. I will have to let you know how they come out.
http://tnttt.com/viewto ... r&start=30
Tadlan
Postby stevem50 » Tue Aug 31, 2010 1:26 pm
i am having great results pulling a 4 1/2x10' teardrop with a honda fit. you should be fine with the civic wagon. and a 2k watt gennie will run a fridge,ac,laptop,lights, and coffee maker just fine. we just got through 10 days on the road with our set-up with no problems. as for storeage a tongue box and roof rack will go a long way
stevem50
Images: 15
