Jim,
Thanks for the advice. I switched to a lighter glove and started paying more attention to my hand, angle, and distance. And I switched to the highest setting and moved slower. I don't really know what happened, but my weld started looking like a real weld. You are right about the breaker. I currently have a 15 amp breaker on the outlet I am using, so I get about an inch and a half before I lose power. When I set up my frame I will set up at least a 30 amp breaker on an outlet in my shop. I've been practicing on my back porch for convenience. My shop is a mess, and I've been slack about getting out there and getting it ready for the build.
Now I understand something one of the welders at the prop shop said. Something like "If you are going to be doing a lot of welding, you are going to want more than a 120." Because there is a 10 minute time limit on use, even with an appropriate sized breaker, I can only do a little at a time. Actually, this is okay with me, as I am generally a slow, work-a-minute, Look-and-ponder-five-minutes kind of guy.
Mini Renegade,
I am sure a Yorkshire man would laugh his a-- off at my attire and groan at my attempts. But running half a dozen adequate looking runs, has me encouraged that I might be able to do this. I am hoping that if I practice and take my time on the REAL job, I can achieve minimum adequacy.
I have a few questions in that regard.
First, I noticed that Wolfgang, who is building the 2+2 also, used rectangular tabs welded on to reinforce his joint where the 2" square tubing angle meets the straight sides.
http://www.tnttt.com/viewtopic.php?t=28640&highlight=wolfgang
This would be the joint I am most worried about with my lack of skills. Is this a good idea? Is there something else I could do to reinforce this joint that would work better?
Second, what about bolting AND welding. On boat trailers that see salt water, bolts are usually the first items to rust out, but for a teardrop, maybe it would be okay to at least single bolt each joint and then weld for dimensional stability?
Third, can I count on some reinforcement of the frame simply from the attachment of the wooden floor and framing?
Thanks again.
I am going to try to move this post to General Discussion so forgive me if this shows up twice.
Peace,
Ravenous
