switterstx wrote: I'm going to keep an eye out for stuff a little closer to the Hill Country. We're heading to Colorado Bend this weekend.
switterstx wrote:So I'm realizing I was reading things all wrong. 4x8 not only refers to the floor/trailer frame but also the profile. Is that correct? I'm going to shorten my frame specs but I like the overhang of the front and back of my profile.
switterstx wrote:What about length? Vertical seams on the sides if the length is longer than 8', does that work? Same for the roof, how bad is it if I seam it?
switterstx wrote:Tallguy: I got all the wood for the floor/foundation of the shed today. Dang!, lumber is expensive. I'm with you. I was going to put off the shed until the fall, when the temperature drops below 90°. Well looks like I'll be raising walls in June/July.
Ira, I want to sit down and visit with you at some point. You remind me of the guys I enjoyed talking to in St. Thomas. I figured on the width thing being an issue, I'm not going any wider than 4'. What about length? Vertical seams on the sides if the length is longer than 8', does that work? Same for the roof, how bad is it if I seam it? I'm not going for woody, too hard to hide my mistakes. Part of my reasoning for finishing the shed first is to get my wood skills up. I just screwed up a saw horse...
Regarding a trailer frame, my dad said I'd need to go with 1/4" wall 2x2 tubing. That seems extremely over-engineered. And my little mig won't cut it for welding that thick, 1/8" is pushing its 70% duty cycle. Granted, he could build it but the weight would be an issue. I wandered around his yard the other day and found 3 or 4 axles that would work, one was the front end of a model T he says. Most of them had big wheels on them, one was a 7 or 8 stud wheel. Maybe I'll get pictures next time I'm down there, see what the bunch here thinks.
One of the trailer was an old sprayer trailer. Had a huge tank (300-400 gallons?) and a gas powered pump originally, now a two axle flatbed. Any tandem axle tears?
I've got to get this d*&$ shed finished...
Tear Les wrote:Scarfing the plywood into longer than 8-foot sheets is common practice. Look that up on your favorite Internet search engine and you'll get more than you bargained for! It's especially used in wooden boat building. There's lot of information here too and Steve Frederick (also on the forum here) has a Builder's Manual that's quite good and explains several ways to do it (I just received my copy and thoroughly enjoyed it).
For your trailer frame 1/4" wall tubing would be considered gross over-building compared to most of the frames used. (There's a link to a frame tutorial ("Trailer Tutorial") at the top of every page.) There are a lot of folks that think 1/8" is even heavier than necessary. As Andrew has said the frame is just a way to drag the body around; it just forms a perch for the body as the body itself is self-supporting and strong on it's own. So if your body weighs, say, 500 pounds, you just need a trailer that's beefy enough to handle that weight plus whatever contents you'll haul.
Tear Les wrote:Somewhere in this vast reservoir of knowledge there are some posts on this very subject and some good observations by our resident engineer (though he lives across the pond) Andrew. If you go to his site (Design Library at the top of the page) and look at some of the .pdf files of his various designs he often has the tubing size and wall thickness called out. Also, have a look at Grant's site http://www.teardrops.net/LilBear/parts6.html#frames as he has spme specs for his frames there and maybe that'll give you some ideas. I just think 1/4" is way over the top but I'm tying to head you to some better info rather than me just flappin' my gums (since I'm not an expert on frames at all).
