magilla wrote:Building my tailgate on the weekend.
My stepfather is a bus body builder with a little trade tip, fit some vinyl to the piano hinge before you fit it, I guess that it would then be held between the body, hinge and tailgate. Will soon find out.
CARN THE PIES !!!
I built the tailgate about 4 or 5 times. The main issue was with how deep it went with the curve. A lot of the trailers seem to have a tailgate that has a curve at top and then finishes straight-ish. Putting that extra bit of curve in made it all sorts of fun.
1. You can't reinforce it enough
2. Use steel if you can - lighter and more rigid at the end of the day
3. Be patient with the gas struts. It's some form of dark magic to get them working!
I ended up assembling it on the ground, test fiting, disasembled and then assemble on the trailer. It is still a little twisted and catches slightly if closed pushing down just one side.
My time was spent a lot on getting the struts to lift the hatch and then preventing the struts from bowing the hatch out when it was closed. I ended up laminating 2x 15mm ply sheets together (after trying metal braces) and curved them to match the end panels. This is the main reason I'd use metal rather than timber next time - weight and strength.
When you bite off more than you can chew, chew like hell...
