teardrop_focus wrote:Hey Zach! Welcome.
Kerry/toypusher said you stopped by to check his tear and that you're super pumped now.
Looking forward to seeing more pics.
Git R done!
paperdoor wrote:Hey Zach , your choice , but look into the trailers at Tractor Supply , for under a buck more they have a 4x8 , pre build solid frame, no- bolt together - the HF I have , I spend alot of time welding up the joints, not a very sturdy trailer just bolted together - and plus you can just drive away with the TractorSupply, and go strait to the DMV for tags and then the lumber yard of your choice.
TimJones wrote:Hi Zach you might want to rethink that piece of wood across the back of your tear. mind is like that and it is a pita to deal with getting things in and out of the back Looking forward to meeting around the fire someday Tim
RonS wrote:Project URABUS? You wouldn't happen to have a tow vehicle with Pleiades on the front grille emblem, would ya?
absolutsnwbrdr wrote:Just estimating my trailer weight....
4x8 plywood is about 25 lbs/.25" thick, or 37.5 lbs/cu. ft.
White pine is about 36 lbs/cu. ft.
Total plywood in my design = 6.55 cu. ft.
Total white pine in my design = .75 cu. ft.
HF 4x8 trailer = about 260 lbs (shipping weight)
Total plywood weight = 245 lbs
Total board weight (roof spars) = 27 lbs
Total estimated weight = 532 lbs*
* this does not include nails/screws, sealer/stain/epoxy/paint, glue, roof material, or doors
Shadow Catcher wrote:One thing to remember if you do not yet have your OB wired for the trailer use the factory connector and save a LOT of grief
