Great Video
Well done! I wish mine was that tidy!
mariannf wrote:Hi Lucy what size and type bolts did you use on the 2x4s? I want to do same. Also how did you tach them? Bolt in from top and then nut from inside c chanel of frame?
mariannf wrote:Thanks Lucy! You'll see I sent you a message asking the same question so please disregard. We have family in phoenix so may be out your way. Have a happy Thanksgiving!
Lucy25 wrote:mariannf wrote:Hi Lucy what size and type bolts did you use on the 2x4s? I want to do same. Also how did you tach them? Bolt in from top and then nut from inside c chanel of frame?
I used 3/8" bolts how you described.
mariannf wrote:Lucy25 wrote:mariannf wrote:Hi Lucy what size and type bolts did you use on the 2x4s? I want to do same. Also how did you tach them? Bolt in from top and then nut from inside c chanel of frame?
Hi Lucy another question if you wouldn't mind. Did you first attach the 2x4s to the trailer then install the ply on top or did you attach ply to 2x4s then attach the whole thing to the trailer? Any detail about construction appreciated.
Vedette wrote:Turkey, Football, and Great Weather..........Wish we were there!![]()
Snow on the ground here, and last night it was -9, No Turkey, and it is a work day for us (no holiday)........But there is Football!
You can always count on Football to brighten any day!![]()
Happy Thanksgiving!
Brian & Sandi
Lucy25 wrote:mariannf wrote:Lucy25 wrote:mariannf wrote:Hi Lucy what size and type bolts did you use on the 2x4s? I want to do same. Also how did you tach them? Bolt in from top and then nut from inside c chanel of frame?
I attached the 2x4s first.
