Model_A Bill wrote:Hi everyone. I've been reading through your posts and found this site to be most informative.
<snip>
With that in mind I was looking at a TD with a total/full weight under 1000#. Is that do-able?
Thanks for all your input. I look forward to learning a lot from you and hopefully meeting you all.
Have a great day.
Bill
Ira wrote:Welcome, Bill!
Anyway, your life is over as you knew it. Yeah, you had the car makeover obsession to keep you busy, but NOW you're gonna find yourself peaking in your neighborhood's garbage can for useful "junk"--and averaging 5 hours a day on eBay.
ENJOY THE RIDE!!!
Currently I am working on finishing a 1930 Model A Tudor Sedan. It is completely original and when it is done, we plan on using it to tour the world....ok, maybe just the U.S!
Jack J wrote:Bill,
Is this what you are looking to end up with? This is a friend of mine that built his to pull behind his stock '29 A. He has traveled around Washington, Oregon and into Canda with it. We usually let him lead to set the pace. His 4X8ft TD weighs about 850 lbs loaded and he does slow down some going up hills. Normal speed for him is around 50-55 on the road. He used Model A fenders and wheels to tie-in the TD to the car.
Here is another fellow in Oregon that we met. Model A and TD and as with any TD, personalized to the owners preference.
You shouldn't have any problem except when people won't let you get back on the road when you have stopped for gas. It will be a magnet for lookers.
Hope this helps
Jack
