Double play trailer idea
Postby jp03 » Wed Jun 27, 2007 1:51 pm
Hi, been watching for awhile and appreciate everyones' input. Just purchased one of the new "REDTRAILER" 5 x 10 footers, to use as a flat bed/RV. Like another person mentioned, some way to convert like a pickup camper style. My present idea is a two foot side wall, around the front and two sides. Then have a tear drop or standup camper cap to slide on and bolt to the walls. The back two feet of the walls could be missing, to allow the whole back kitchenett/ bulk wall to add support. Only other thing i would like to mention is about the class hitch tongue weights. Some people have mentioned about overloading them highly. Class 1 is 150 lb, Class 2 is 250 lb., and class 3 I believe 350 lb. Please be awear of these factors. I am using a toyota matrix, to tow the redtrailer, and had to weld up the hitch to accept an 18 inch height. Matrix hitch receiver is made below the spoiler, so a good four inches lower then average hitch. Thanks again from everyones 2 cents!
jp03
Postby Miriam C. » Wed Jun 27, 2007 1:58 pm
Image to the playground JPo3. Haven't seen a tongue weight that was too heavy by class weight. However not sure I was looking. 8) :D
Enjoy the site. I would love to see an ongoing photo story of your design. We have a thing for pictures. Keeps the bubble oil level. ;)
Postby cuyeda » Wed Jun 27, 2007 3:35 pm
At the last rally that I went to, someone had built a slide in teardrop on a trailer for dual purpose.
Check my album, specifically pictures:
http://salsaholics.com/uyeda/gallery2/m ... &g2_page=2
Cliff & Vanessa
cuyeda
Postby pauld3 » Wed Jun 27, 2007 3:49 pm
Pictures! We want, no ... we demand PICTURES!!! :lol:
Welcome, too, by the way! 8)
Lynn
Paul & Lynn Donovan
The Toad Drop Inn
Liberal, KS
pauld3
Images: 94
Postby jp03 » Wed Jun 27, 2007 5:14 pm
Thanks Cuyeda, but hoping to blend the side a little more to blend into looks. Guessing to use the 2 x 4 side post/rail holders for the bottom wall potion. Incorperating 2 x 3 wall, to have a top lip to bolt down top partion. Still plainning, may not get to the camper top until next year.
jp03
Re: Double play trailer idea
Postby Tear Les » Wed Jun 27, 2007 7:15 pm
jp03 wrote:Hi, been watching for awhile and appreciate everyones' input. Just purchased one of the new "REDTRAILER" 5 x 10 footers, to use as a flat bed/RV. Like another person mentioned, some way to convert like a pickup camper style. My present idea is a two foot side wall, around the front and two sides. Then have a tear drop or standup camper cap to slide on and bolt to the walls. The back two feet of the walls could be missing, to allow the whole back kitchenett/ bulk wall to add support. Only other thing i would like to mention is about the class hitch tongue weights. Some people have mentioned about overloading them highly. Class 1 is 150 lb, Class 2 is 250 lb., and class 3 I believe 350 lb. Please be awear of these factors. I am using a toyota matrix, to tow the redtrailer, and had to weld up the hitch to accept an 18 inch height. Matrix hitch receiver is made below the spoiler, so a good four inches lower then average hitch. Thanks again from everyones 2 cents!
If you need some specific information this may help.
Hitch Class Tongue Wt. Capacity
Class I 200-250 lbs.
Class II 250-350 lbs.
Class III -IV 350-600 lbs
Class V 1,000 lbs. +
Hitch Class Inside Measurements
Class I 1-1/4" x 1-1/4"
Class II 1-1/4" x 1-1/4"
Class III - IV; 2" x 2"
Class V; 2-1/2" x 2-1/2"
Welcome aboard. :thumbsup:
Les Lampman
Tear Les
