Newbie from Texas (D/FW)-Needs HELP,Please!
Postby aprazr56 » Thu Dec 31, 2009 5:25 pm
Hello all,
You each have what appears to be a unique trailer. Yhey are all beautiful in their own way.
I have a 5'x8' utility triler that tilts(of course I will fix that) and am wanting to convert it to a Teardrop to match my 97' Jeep Wrangler (white). I would like to know if there are any 'plans' out there to accomodate this task. I have searched the web & found none.
Do I just start from scratch? I would like one with a kitchen in rear, a place for window unit and skylight. (of course any extras as: original jeep wheels, flares, etc.)
Thanks,
Gregg White
aprazr56
Images: 84
Postby Ageless » Thu Dec 31, 2009 5:33 pm
At the top of the page; link to the design library
http://www.angib.pwp.blueyonder.co.uk/teardrop/tear00.htm
Ageless
Postby ajordan » Thu Dec 31, 2009 5:43 pm
At the top of the page is also a link to "Generic Benroy Plans". It construction directions and would be a good place to start. I am still working on a set of plans for mine and have used this and the design library for ideas. Good luck!
ajordan
Welcome from Asheville!
Postby Alfred » Thu Dec 31, 2009 6:07 pm
The Generic Benroy Plans at the top of the page are a good place to start for step-by-step instructions, the Design Library, also at the top of the page, is great for its drawings of several different potential campers.
I would also check-out Mike S. Weekender Plans, available here: http://www.mikenchell.com/weekender/
I am building a modified version of the Weekender...
And welcome to the T&TTT group!
Al in Asheville :thumbsup:
Alfred
Images: 368
still have a question, please
Postby aprazr56 » Fri Jan 01, 2010 1:04 pm
Still need to know if I can use my 5x8 utility trailer and if so, how do I move the axles/springs/etc.? It is a Heavy Duty (3,200 lb rating)
I just went out & looked at it again & it has side rails (which will need to be removed) and the tires are directly in the center of gravity for this type trailer.(which will need to be moved backwards or lengthen the tongue)
Any suggestions as to 'how' to move the axle/wheels? I have read all the drawings & 'how to's' as well as plans but find nothing about the axles/wheels.
Thank again for your replies,
Gregg
D/FW, Texas
aprazr56
Images: 84
Postby Mike_La » Fri Jan 01, 2010 2:15 pm
Gregg,
Posting a photo of your trailer would help us, help you.
There is a post on converting a utility trailer to a TD. If I run across it, I'll post the link.
To re-position the axle, you'll have to cut the spring hangers and re-weld them it the appropriate location(where ever that may be).
Link to Trailer Balance Spreadsheet
Mike
Mike
"Believe you can and you're halfway there."
Theodore Roosevelt
Mike_La
Images: 71
Postby aprazr56 » Fri Jan 01, 2010 4:58 pm
removed
aprazr56
Images: 84
gues i can't upload
Postby aprazr56 » Fri Jan 01, 2010 5:01 pm
Well, with out much adew, I guess I can't figure out how to upload a saved picture onmy computer.
I will try more later unless someone has a 'quick fix'
Thanks again,
Gregg White
D/FW Texas
aprazr56
Images: 84
Re: gues i can't upload
Postby Mike_La » Fri Jan 01, 2010 5:13 pm
aprazr56 wrote:Well, with out much adew, I guess I can't figure out how to upload a saved picture onmy computer.
Thanks again,
Gregg White
D/FW Texas
Gregg, you'll have to upload to your album. Make sure you re-size your photos to 640 X 480.
Help with photos
To get to your album, Click here, then click on "Your Personal Gallery" at the bottom of the category list.
If you're running Windows XP, Click here for a free Image Re-sizer. You'll find it on the right column of the page, a little over half way down.
Mike
Mike
Theodore Roosevelt
Mike_La
Images: 71
Hello Mike
Postby aprazr56 » Fri Jan 01, 2010 5:22 pm
I got it re-sized & in my album, but now I can't figure out how to upload it to this thread.
aprazr56
Images: 84
Postby aprazr56 » Fri Jan 01, 2010 5:35 pm
removed
aprazr56
Images: 84
well, forget the link
Postby aprazr56 » Fri Jan 01, 2010 5:39 pm
Mike,
I think I finally figured it out that any member can 'click' on 'my album' to see the photo. Right? Please let me know if otherwise.
Thanks ever so much,
Have a 'Blessed' New Year to You & Yours,
Gregg White
aprazr56
Images: 84
Postby Mike_La » Fri Jan 01, 2010 6:02 pm
Yes, any member can access you photos.
Once up-loaded, your photo will have a web(url) address. Insert the web address into your post, along with the image CODES at the beginning and end of the web address.
BTW, Please edit the post where you tried to place the image. It's too big and takes up too much room.
Now that I can view your trailer, we can give you help.
Mike
Theodore Roosevelt
Mike_La
Images: 71
Postby aprazr56 » Fri Jan 01, 2010 6:04 pm
removed
aprazr56
Images: 84
Postby aprazr56 » Fri Jan 01, 2010 6:05 pm
well, it uploaded to your post in lieu of mine.
Thanks for all your help.
Now, any thoughts?
Thanks again,
Gregg
aprazr56
Images: 84
Users browsing this forum: TwilaR and 2 guests
