TeeJay87 wrote:A big concern is the amount of electricity consumed by an A/C unit in Texas heat. Can a battery support that. Is that dependent on insulation, a nice shady spot, reflective surfaces, etc..?
TeeJay87 wrote:After reading in the electrical subforum, I'm convinced with a proper battery, great insulation, great timing (when to cool / not cool), and hearing stories like your friend's, it can be done!
Thanks for your 2 cents,
Trent
Jason and Amanda wrote:Coming from a guy who is currently living out of a tent in Afghanistan and using outdoor/semi permanent showers...
It's actually pretty easy, you will mentally and physically adjust after a mere week and then your living conditions will become normal to you.
I have some things to point out for you to keep in your back pocket.
1. HVAC units basically require 110v to be practical. You might as well plan to be "plugged in". Specially if your job is professional and requires you to not be stinky and sweaty.
2. Your going to need some form of shelter, you can get that from screen houses and tents for short term, but those quickly deteriorate from the sun's UV rays and will not work as a permanent shelter. You are probably going to have to choose between living in a backyard or at a year round RV park, unless you spend $$$ on a long term UV resisant shelter, similar to the HUGE tents the military uses.
3. You will need running water, anyone can go a week with bottled water and baby wipes, nobody (with a professional career that requires a kept appearance) can go 6 months. Again, back to the friends house or RV park.
4. Your going to need some storage for your stuff, I assume you can leave your big items either at your parents or in a storage unit, what I mean is that you are going to need storage for your clothing and what not. And a way to wash your clothes. For storage, us deployed members just fabricate shelves out of plywood or use plastic storage bins big enough to store shirts, underwear... etc. Clothes can be washed at a laundromat or friends house.
5. You're eventually going to need to store cold and frozen perishable foods, you can only eat non-perishables for so long before you get fed up. Either invest in a nice portable fridge or use a friends house. If you do end up at an RV park with 110v AC power, a small dorm room or office fridge will work too, and is much cheaper. But you will need a place to keep it... going back to shelter.
6. Your going to NEED a place to change, stand up, sit up right in a chair, etc... think shelter again.
I JUST bought the Eureka northern breeze, this is designed for the weekend camper though, and will not hold up to being exposed to the elements for 6 months straight. portable shelter, IE tents, are VERY expensive if you want them to be semi permanent and stay exposed to the elements for more than a few days at a time.
