Hello from Chester UK
Postby Geoff Ryall-Harvey » Sat Jul 17, 2010 2:31 am
Hello to all. My name is Geoff Ryall-Harvey, I live in Chester UK. I'm 52 and used to run a management consultancy company that held contracts with the Department of Health. A couple of years ago I retired to become a full time stay at home dad to our baby daughter.
Previously I was an enthusiastic Citroeniste, owning most of their modern classics. I then built several 2CV powered Avion trikes (see below).
I've always been a frustrated hot rodder and about 5 years ago I took the plunge and started to build a T Model Ford. Plan was to finish it in a year. Unfortunately (or fortunately) my business took off and I was too busy to finish it. I then flipped houses 5 times in 3 years in order to get my mortgage down as low as possible. I'm now back into the build and making good progress towards finishing this year.
The Rod is a Modified - it's an all steel 27 body on a boxed, pinched and Zeed 1921 One Ton Model T Truck chassis. It has a 1957 347 Pontiac engine with a 3 speed gearbox and 3 pedals. Front brakes are 1950 F1 on a suicided 39 drilled I beam and a Model A spring. Rear axle is an unknown Ford on a Model A spring (the axle is behind the spring). Seats are from a Dakota (DC3), Steering is cross steer using a Burman box. There are a lot of aircraft bits on the car and when it's painted I think I may have it signwritten as if it were a car sponsored by an Arizona aircraft scrapyard/supply company. It's not really a theme - but just the way I'm imagining a car like this could have been built.
I also have a 54 100e with a 2 litre Pinto - but that has to go eventually as I've just bought a Nouva Fiat 500 as it's more practical and comfortable on a daily basis for the little girl. I've done a whole lot of work to the 100e since I bought it (new s/s exhaust system, a really nice interior from a Cinquecento Sporting, ally fuel tank, new rad, decent tyres, powdercoated bumpers and wheels, just started a rewire). Sadly it will be in the classifieds as soon as I've finished the rewire.
Hot rods and teardrops seem to go together and having just paid about $3000 a week to rent a Villa in Italy where the accomodation turned out to be less than basic (and not very clean either), I think it's time to invest my annual holiday budget in something a bit more permanent.
That's it really.
Geoff Ryall-Harvey
Postby Shadow Catcher » Sat Jul 17, 2010 7:02 am
For the price of that Italian Villa for a couple of years $>
You can definitely build a very nice teardrop with a real period Hotrod look. Looking at your other projects I look forward to what you decide to build.
Postby Creamcracker » Sat Jul 17, 2010 8:38 am
Is that a Ford Anglia or Popular in the last pic 580UXK? Nice trike by the way.
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby Geoff Ryall-Harvey » Sat Jul 17, 2010 12:01 pm
Thanks for the welcome.
The 100e is an Anglia. The trike is my old faithful - I went to Rome in it last summer and have often done 500 miles in a day in it. Unfortunately, I did an artic circle tour in it and the road salt played havoc with all the fine finishes. It was show winning but after that trip things like chromed linkages, levers, adjusters, rose joints etc etc have all suffered. The painted wire wheels have rosettes of rust around each spoke. I'm working my way through it and sorting it all out whilst still keeping it on the road.
I'm intending to finish the Modified and refurbing the Avion before I start in on building a TD but as soon as I sell the 100e I will put the £2000 I will get to collecting parts.
I want to build something tradtional and simple - but wide and may be with a bunk/stretcher/hammock across the cabin for the little one. Campsites are more crowded here and I don't like the idea of leaving her in tent, or even the awning, outside.
I'm thinking construction will be in Glasonite - a material used here for truck/lorry body sides. It is a glassfibre and plywood sandwich. It's available in huge panels and commercial vehicle breakers yards are happy to give it away. Other hot rodders have used it with some success - the black one below was built using Glasonite by noted UK hot rodder Steve Lang.
I also collect paraffin pressure stoves and lamps - so I'm intending to incorporate those into the galley.
Geoff Ryall-Harvey
Postby Mini Renegade » Sat Jul 17, 2010 12:25 pm
Hello and welcome to the forum from another Brit. I love the 2cv powered trike! I wanted a Lomax 223 kit car a few years ago but ended up buying a Mini Clubman estate.
You should have a look at the Teardrop club GB website www.tcgb.freeforums.org for more brit builders/owners.
If evvr tha dus owt fr nowt, allus do it fr thissen
Mini Renegade
Postby jackdaw » Sun Jul 18, 2010 5:21 am
HI Geoff,
Welcome to the forum form another Brit on the board.
I've seen Steve Langs build over on the hotrod forum. It looks great. :thumbsup:
Check out the design library at the top of the page for a few other profiles that might be suitable.
I favour the Grumman2, as the galley can be set right at the back, and you don't smack your shins when your using it. :thumbsup:
Have fun gathering parts. It's all part of the journey :D :D
Dave
jackdaw
Images: 124
Postby Geoff Ryall-Harvey » Sun Jul 18, 2010 2:26 pm
Dave - thanks for the tip. The Grumman2 looks to be just what I'm after.
I'd certainly want a 5' wide one. What's the view on 6'? Too wide??
Geoff Ryall-Harvey
Postby jackdaw » Sun Jul 18, 2010 3:24 pm
Geoff Ryall-Harvey wrote:Dave - thanks for the tip. The Grumman2 looks to be just what I'm after.
My first Grumman is 5'8" wide, and it's cavernous..... for a teardrop. I've nearly finished building my second Grumman, that will replace our first. I've made a few weight saving changes, including cutting the width down to 5'4". It's just right to fit the fridge, hob and sink unit in from an old caravan. I don't think we'll miss the 4" in the cabin.
Here's a link to the build thread We've had a lot of fun building each of the trailers, but this one even more so :thumbsup:
Cheers Dave
jackdaw
Images: 124
