Hi there, I'm Geoff, Live in Bristol UK & have aquired a 'Little Guy' deluxe (now called the Rascal i think?) I'm told by the UK importers that its the first one that was imported back in 2005. I've modified the rear panel & mounted round lights instead of the original oblong lamp units that looked like thay had come from a farm trailer! while I was fitting the lights I (I hope) cured the water leaking into the rear of the pod from a loose side joint & also a bad fitting rear seal on the cooking area cover.
I did leave a message on the American Little Guy site about the wheels & what the lug patten was, I still have no answer & have found out that its a Ford stud patten.
I'll post some pictures when I can as I'm customising the Little Guy as I'm taking it to car shows here in the UK behind my 1994 custom Chevy Astro van.
Cheers for now
Geoff
