Starting from the ground up!
Postby Ashleymeadow » Thu Jul 14, 2011 2:07 am
Tire size. That's where it begins. I have to do that first so that I can order the right axle because I want at 60 inch interior. This is going to be a big project!
I think that I have the right axle picked out; it is the torsion axle from Northern Tool rated for a 2000 lb. GVW. The TD will be 10' long. How am I doing so far? If I am going wrong, let me know.
Jerry
"If we falter and lose our freedoms, it will be because we destroyed ourselves."
Abraham Lincoln
Ashleymeadow
Postby madjack » Thu Jul 14, 2011 3:09 am
Welcome Jerry, other than the axle from Northern, I'd say you are doing fine...I would look for one from Flexiride or Dexter rather than the (un)Reliable Axles...would also consider a 60" exterior to make better use of available materials...but you are right about tires...they, along with what wheels(more important) you are planning on using will dictate final axle dimensions.................
Queen mattress
Postby Ashleymeadow » Thu Jul 14, 2011 10:59 am
I am trying to install a blow-up queen bed, then cover it with memory foam. I thought of the 4x8 size of plywood, and the top, front and hatch are going to have to be seamed anyway. I will loose a 1x8 on each sheet, but do not know where I would need that 1x8 plywood. Am I missing something?
Abraham Lincoln
Ashleymeadow
Postby starleen2 » Thu Jul 14, 2011 2:25 pm
starleen2
5th Teardrop Club
