another newbe build
another newbe build
Postby the hunter » Sun Jul 14, 2013 7:52 pm
so little bout me im always on the river or in the woods when not working tired of tenting it as im getting older want more comfert im loc in pdx
so ive been looking at different modles on line for a bit and i think i need a bigger tear drop im thinking of 5x10x6 but im wooried bout the weight wood like to stay at or under 1000 lbs im thinking i should insulate as i will be useing it in the winter were it can get into the teens wood like a sink and water jug that wood hold bout 20gal if possable and want 110 and 12 volt im wanting to add a propane tank up front for the stove and barbque mouted to side of unit
in thinking of leading towards more of a square style for frist build i think there called a lof style so im good at constrution any advise and thoughts and is this possable and did i forget anything thanks all Bob
the hunter
Re: another newbe build
Postby mezmo » Mon Jul 15, 2013 10:01 pm
Welcome Bob/the hunter,
Builds range from basic to elaborate - it all depends what you want.
Check out the info in the "Design Resources", located in the header,
and spend time looking through the build journals and other sections
located in the "TINY TRAVEL TRAILER DESIGNS" portion of the site.
Happy planning and building.
Norm/mezmo
mezmo
Images: 194
Postby Roly Nelson » Thu Jul 18, 2013 1:07 am
hI Bob welcome to the forum at first I thought that your computer didnt have a capital letter key but i see you found it when you mentioned your name you have some great ideas that surely will suit your needs camping for many of us mean lots of different things since we all have ideas that only suit ourselves if you know what i mean so all i can suggest is that you follow your dreams and build what ever style rig you want there are all kinds of designs so build what suits you best and no one will fault you for it there is a bunch of info on this site so check them all out and be sure to ask any questions you want since we are here to help i hope this helps with your build since many of us were in the same place you are right now..............whew, i'm not used to such long sentances i better stop before my capital letter key thinks i'm mad at it and makes me continue to right in lower case lettering forever good luck on your build.
Roly, the little ol td builder in so calif..........keep in tutch!
Roly Nelson
L'il Ol' Woody Builder
