jdfdave wrote:I think I want to finish the exterior of my teardrop with paint, however my concern is sealing the ends of the plywood ends to make them weatherproof. What do you recommend? Also, can I just use good exterior paint for the sides and maybe the top? The roof is 1/4" plywood. Open to any suggestions.
jdfdave wrote:Thanks for your comments. Since this is my first build I am trying to keep it simple. If I am understanding you correctly, I can use a good quality exterior paint, oil based for the sides and top. Do I need to do anything special to the plywood ends that are exposed? Just paint or some kind of special sealer?
citylights wrote:jdfdave wrote:Thanks for your comments. Since this is my first build I am trying to keep it simple. If I am understanding you correctly, I can use a good quality exterior paint, oil based for the sides and top. Do I need to do anything special to the plywood ends that are exposed? Just paint or some kind of special sealer?
The "classic" designs call for a coat of epoxy thinned with 50% mineral spirits to penetrate and seal the wood. This is especially important at the plywood ends. Search for "rot doctor plywood seal" and their CPES product.
Check here for more info
http://www.rotdoctor.com/test/polytest/polytest.html
With that said, I used latex household exterior paint on mine, but I plan to skin in aluminum over that.
