square shooter wrote:I have looked online, and not fond an answer. I am designing and building a lightweight trailer of around 120 lbs. overall sprung weight. I am hoping you can help. The springs are leaf type. The distance between the eye and slider nylon is 21". The axel travel will be 3". What should be the weight requirement to deflect each spring 1" ? 60 lbs? Do you know of anyone who's built such light rate leaf springs?
