hello from the U.P. of Michigan
Postby rdemler » Fri Jan 31, 2014 4:12 pm
Hello.Looking to build a enclosed camper from a 7x14.Having a hard time determining weather I should go all aluminum for more money.Having the inside wiring etc done before I buy it.So many decisions....Been readin alot of the posts and gaining some ideas.Will be towing to Montana for a couple weeks each year,and camping local as much as possible...Well,back to reading posts.Thanks for having me.
rdemler
Re: hello from the U.P. of Michigan
Postby Shadow Catcher » Fri Jan 31, 2014 6:47 pm
Welcome from a bit further south. We have a Teardrop that we like very much, but some of the decisions that went into the choices we made. The one important to you was the decision for an all aluminum frame. The two things that fail long term are wood and rust, and the all aluminum frame cures one of those nicely and reduces weight significantly. If I were ordering a trailer I would not have it wired and would not have the wood sheathing installed, You will need it off to add insulation and where you run wires and where you want them will differ than what the manufacturer is likely to install. If you do it you can make sure it is done well with the best choices in materials. Choices Progressive Dynamics power center, solar for boondocking, LED lights...
