Hi Fron Central California
Postby tyellow57 » Tue Aug 19, 2014 1:03 am
Hello all, I'm Troy
I have started on my teardrop already, . Doing all the work myself. Hope to raise the walls soon. I run into a guy and his wife at San Simeon, Ca. Been hooked ever sense. I'm always thinking about my teardrop, trying to figure things out. So far it all has. Is lots of fun working on it, and can't wait to take it out. Still trying to figure out how I want the galley to look, the rest is easy, :worship: kinda ha ha. I have looked at so many pictures of galley's, they all starting to run together. Well I hope I'm doing this first post right. 8) Happy Camping Troy.
tyellow57
Re: Hi Fron Central California
Postby Vedette » Tue Aug 19, 2014 10:09 am
Hi Troy
Welcome to the Forum! :thumbsup:
There has been much debate in the past about sinks in Galleys?? :thinking:
Don't waste your time or the space with a sink! :roll:
You will save yourself a lot of time and money!!
As you must remember everything else that will come along with putting a sink in your TD.
ie. Water inlet, or water storage tank, pump, faucet, plumbing, drain, grey water tank, etc. etc.
There is lots to read here on the Forum.....search the archives.
Check out the Electrical section........there is a ton of good info there.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby ctstaas » Tue Aug 19, 2014 4:48 pm
Hi Troy, I built mine before I found the site and she turned out OK But would have been a great asset with great folks. I left my galley unfinished but it works great. I'll finish it more later. Right how I'm working on a slideout folding table with a small sink attachment that mounts to the inside wall of my galley and takes up close to zero space when not in use. I have four projects going on for my first build and can think of another. None are needed for good times camping but I can't stop making stuff. The folding bench is eight screws away, the running board still need to be welded, the swing out icechest carrier and roof rack are still on the drawing board. Get it to a point and finish later,,, way later, never?
Enjoy, Chris
ctstaas
Postby kjphotopro » Tue Aug 19, 2014 9:35 pm
Welcome! We just moved out of Paso Robles a month ago, now we're in Alabama. Say 'hi' to the seals for us! 8)
:pictures:
kjphotopro
Postby tyellow57 » Fri Aug 22, 2014 10:02 pm
Hi Brian & Sandi
Brian I was thinking the same thing about the sink. Love you Build, very Nice. Troy
tyellow57
Postby tyellow57 » Fri Aug 22, 2014 10:05 pm
Hi"kjphotopro"
Every time I go to San Simeon I have to go see the Seals.
tyellow57
Postby tyellow57 » Fri Aug 22, 2014 10:08 pm
Hi Chris
I know what you mean about building stuff. I have lots of ideas but not sure which one to settle on. Thank Troy
tyellow57
