campnfish wrote:Wow, 275 days of fishing is a very good year! If my trailer had shelves and a galley, I'd probably use it as a storage unit, maybe it's better in a way that I don't have a galley, can't overload and squirrel anything away in it!
Hi Campnfish (By the way, handles seem so impersonal, do you have a first name we can address you with?),
I hope I did not leave you with the understanding that I fished all those days in succession
I was living and working near Saratoga Springs, NY and during the summer daylight savings months, I could work all day, run home, grab a sandwich, change clothes, hook up to the boat, and be on the water in about 20 minutes ... including a gas stop, if I failed to gas up on the way home from the last trip
BTW, I took a peek at your galley pics and your TD looks nice and my wife loves your quilt and I like the use of the "Cot side pockets" or as Cabela's calls them,"Cot-Side Nightstands" for storage ... GREAT USE of SPACE
About galley space, I do not carry a ton of food either ... I plan for a few days to about a week max for one or two and because I have the space, I usually carry two Ice chests ... one is a Coleman Extreme that slides in the bottom of the galley - it is used for food storage and gets opened only a few times a day. The other is an older ice chest that I had and use it for sodas and water. A few canned goods go in a basket under the bunk/s, fruit and anything fresh goes in a basket or fruit hammock in the galley area.
The trailer lights, small LED TV (Just installed), radios (AM/FM & 2m Ham), and small fan/s are all 12vdc and run off a single group 27 deep cycle battery --- good for 4 - 7 days depending on how much electricity gets used. If the battery starts to drop too much, I either plug in somewhere or start the little genny (1800 w) to charge things back up
A couple of trips in Arizona, my prospecting buddy and myself would sit around in the evening and play cards or BS until it was time to turn in ... those trips the lights were incandescent and because the temps were quite warm in the evening hours, we would run a fan or two two keep the air moving, and the lights on, the battery needed charging about every third or fourth day ... not too bad
Anyway, good luck with your TD and your fishing excursions ... Check out the Tear Jerkers site and maybe you'll be able to hook up with folks in your area (The Northeast, I presume) and make a gathering or two.
Take care and ... enjoy
