MA Newbie
MA Newbie
Postby Kaz » Tue Sep 23, 2014 6:20 pm
Hi, new to this so bear with me. Started building a 5 x9 teardrop from scratch. Working on chassis now, trying to figure out what type of axle to use. I'm partial to leaf springs. Post some pics when I figure out how to .posting.php?mode=post&f=40#
Kaz
Kaz
Images: 122
Re: MA Newbie
Postby George Taylor » Tue Sep 23, 2014 7:28 pm
Welcome. Alex will also depend on weight of trailer. What area of MA are you in?
George Taylor
Re: MA Newbie
Postby Kaz » Tue Sep 23, 2014 7:32 pm
South Shore 20 minutes from Plymouth.
Kaz
Kaz
Images: 122
Re: MA Newbie
Postby ts04011 » Wed Sep 24, 2014 7:22 am
Welcome. The axle decision... that's important, this forum has many discussions on weight, wheel size, hub bolt pattern , positioning etc.. and can be overwhelming but on the bright side see how much you will learn.
and at the end you realize... it was not that bad after all.
FYI... I have not figured out how to load Photos but I have posted my build in Google + if your interested in seeing .. let me know
There are tons of sites on this topic once you start researching
https://www.storesonlinepro.com/store/2 ... 7c8a3ff25b
http://www.richardflake.com/trailerchassisbuild.htm
ts04011
Images: 16
Re: MA Newbie
Postby bobhenry » Wed Sep 24, 2014 8:24 am
At 5 x 9 you will probably come in somewhere around 1500 pounds. The type of axle is far less important than dialing in to the right weight capacity.
I would like to say I just purchased a 5 x10 flat bed trailer with my first torsion axle suspension and notice each tire reacts singularly to rough spots without transmitting the shock thru the axle to the other tire.
Re: MA Newbie
Postby jonw » Wed Sep 24, 2014 12:07 pm
Welcome from another Masshole! :)
I too used a torsion axle for my build and it rides like a dream - no bouncing around.
Good luck with your build and lets see lots of pictures
jonw
Titanium Donating Member
Images: 163
