newb from Colorado
newb from Colorado
Postby tgsTD » Thu Oct 02, 2014 10:01 pm
Came across y'all's great forum looking for ideas for a teardrop camper to pull behind my 4Runner.
Planning on more backcountry trips thru the West and Southwest as well as a long trip back and forth to Alaska.
Looking for preliminary thoughts on a high clearance frame (already started checking out military surplus trailers) as well as a 10' length for space and comfort.
Any ideas and help would be greatly appreciated. Thanks ahead of time for your time and experience!!
Terry
Terry
tgsTD
Re: newb from Colorado
Postby bc toys » Fri Oct 03, 2014 8:03 am
Welcome Terry hope you find lots of info on this great site
bc toys
Images: 42
Postby High Camp Trailers » Fri Oct 03, 2014 11:35 pm
Hi Terry,
Using a local weldor to build you the exact frame to your exact specifications (starting height, tubing size, where you want cross members, attachment points, tongue length, etc) is usually the best method if you know what you are eventually going to build. You might as well invest the effort up front in figuring out the end product anyway and save yourself headaches "down the road" - don't just start with the frame and wing-it from there, you'll find that common sizes for plywood, aluminum sheet, moldings, etc... might make building a teardrop body on that unusual size frame difficult. If you are thinking about building with some standard TD body dimensions found on the forum here (4' x 8', 5' x 8', etc) you should be able to figure out body size and frame size pretty quick. Then you just have to shop around locally and find a good weldor who isn't going to fleece you.
Good luck and happy camping!
HighCampTrailers.com
Portland, Oregon
(503) 869-9825
High Camp Trailers
Images: 36
