Small Trailer for 4
Small Trailer for 4
Postby harrell79cj5 » Thu Jan 07, 2016 4:47 pm
I am going to be builing a small trailer that will sleep 4. Not my first time building and designing things, but my first travel trailer. I will mostly be a lurker and getting information from other's builds. Dimensions will roughly be 6.4W x 10'L X 4.5'H including a 1.5' galley on a 12' trailer with a 2ft open space on the fron for gear. Sketch attached. Two smaller bunks are elevated to create storage as well as seating and will have a fold down table that goes where the middle bed is using those n=bunks as the seats. Sleeping will be parallel to the axle.
LC.pdf
(88.73 KiB) Downloaded 200 times
harrell79cj5
Re: Small Trailer for 4
Postby AZ_Desert_Rat » Thu Jan 07, 2016 9:30 pm
Hi harrell79cj5, welcome to the site... :applause:
You have an interesting idea and have a plan on paper... I am curious whether you have tried to mock up your plans; the reason I ask is that the inside height seems tight to be sitting up to a table? :thinking:
Just curious and good luck with your build and keep us posted on your build with posts and pics...
:pictures: :pictures:
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Postby harrell79cj5 » Fri Jan 08, 2016 10:43 am
Yes I did some mock up on that portion. Thats why I went 4.5' instead of 4'(which would work better with wood sizes and keep it lower). The benches/bunks are only 12" tall, which will make a for not as comfortable seating but it will really only be to play games etc if it is nasty weather. Thanks for looking and I am sure there will be many things that change once I start building.
harrell79cj5
Postby lrrowe » Fri Jan 08, 2016 12:37 pm
And will you be comfortable with the mattress being in the doorway access?
Bob
lrrowe
Images: 439
Postby harrell79cj5 » Tue Jan 12, 2016 4:06 pm
Yes, the matress will only be foam that can be rolled out of the way. I figure 90% of the time we will just be crawling in to go to sleep anyway.
harrell79cj5
