Mass Newbie
Mass Newbie
Postby Bioheat » Sat Jun 11, 2016 6:24 am
Hi guys and gals, I'm new here. No duh right? Well I own a 1965 Land Rover and go to several Land Rover events every Fall. My wife and I have been sleeping in the back of the truck, but in Massachusetts, it gets very cold in the late Fall. So she has told me we need to have a camper, but these events tend to be in farmer's fields, which means a very narrow gate to drive through. So I came up with a plan....I have several load beds from Land Rovers of the same vintage as mine, and the top of a full hard top. I'm gutting two pop-up trailers, cutting the chassis down to size on one, and using it as a base to build a Land Rover pop-up tag along trailer. I know not really a tear-drop, but it'll be about the same size, it'll match my truck, and fit through those narrow gates. And in case you're wondering what that truck looks like, this is it: Image
I'll start a build thread soon, this whole thing needs to be complete by the end of September when metal dash starts, that's the first event.
Bioheat
Re: Mass Newbie
Postby KennethW » Sat Jun 11, 2016 6:38 am
You will want to insulate the camper. That steel will be cold. Is the box double wall? Maybe spray foam between the two. Have fun :thumbsup:
KennethW
Images: 82
Re: Mass Newbie
Postby Bioheat » Sun Jun 12, 2016 11:27 pm
KennethW wrote:You will want to insulate the camper. That steel will be cold. Is the box double wall? Maybe spray foam between the two. Have fun :thumbsup:
Hi Ken, no the box is single wall aluminum. I had planned on using 2" pink foam insulation, then covering that with a cloth covering, or head liner material. The biggest problem these trucks have id it tends to rain inside from condensation, so I was going to try and nip that in the butt with the camper and insulate it thoroughly!
Bioheat
Re: Mass Newbie
Postby Old Rookie » Wed Jun 15, 2016 9:49 pm
Like your TV! :thumbsup: Look forward to your progress pics.
Ken & Ruth
Okies from Muskogee
Old Rookie
Images: 5
