Hello from Metro-Detroit!
Postby dodin » Wed Mar 31, 2021 10:49 am
Hello all! I have been reading lots of posts here on tntt and I finally have an account!
My planned build is not a tear drop camper at all, it's a slide-in truck camper. Boyfriend and I bought an old tiny camper meant for 6 foot beds and it fit right into our '97 single cab Tacoma. It's riddled with water damage but its got plenty of usable parts like jacks, windows, and a door.
After much deliberation I plan on building it from the ground up again. I haven't decided materials yet, so many pros and cons. I thought I'd include a list of some methods I'm considering:
Classic Wood Frame, XPS Foam insulation, Plywood interior and exterior paneling
--PMF exterior
--Fiberglass exterior
--EPDM Roof and Aluminum sheet exterior
Foamie, XPS Foam Reinforced by either PMF or Fiberglass
Classic Woodie PMF pros:
--Cheap
--Common
--PMF flexible with expanding and contracting wood
--Minimal fumes
Classic Woodie PMF cons:
--Lots of effort and prep
--Can leak over time
--Smooth finish nearly impossible
--Seams sit proud
Classic Woodie Fiberglass pros:
--Tried and true by boat builders
--Seamless finish is relatively possible
--Essentially waterproof
Classic Woodie Fiberglass cons:
--Fiberglass cracks and damage more likely than flexible PMF
--Over 2 fold the price of PMF
--Fumes and environmental hazard
--Potentially will undergo stress due to wood expanding and contracting?
Classic Woodie EPDM x Aluminum pros:
--Tried and true classic RV and TD construction
--Hard sided vehicle
--Waterproof
--Looks manufactured, thus higher resale value
Classic Woodie EPDM x Aluminum cons:
--EXPENSIVE
--Corner moldings and trim are prime places for water intrusion and damage
--Possible EPDM delamination
--Aluminum dents, painted aluminum essentially can't be corrected
Foamie x Woodie with either PMF or Fiberglass exterior Pros:
--Almost entirely waterproof in and out
--Relatively Cheap
--Lightweight
--Easy to sculpt and shape curves
Foamie x Woodie w/ PMF or FG cons:
--Not a lot of examples I've found online thus far
--All mounting points for camper ex. Jacks, Ratchet Straps, Windows, Roof Vent, Door, Floor, etc. require wood, so kind of not a foamie.
--Not certain about it's strength
--Question: If foam is made of plastic, wouldn't it have a high coefficient of thermal expansion?
So voila! Essentially this is a summary of my research in very broad terms.
Thank you for your time! If any threads come to mind about said points I've mentioned, please direct me to them!
dodin
Re: Hello from Metro-Detroit!
Postby QueticoBill » Wed Mar 31, 2021 11:32 am
Welcome!
QB
QueticoBill
Images: 22
Postby dodin » Fri Apr 02, 2021 3:02 pm
Thank you!
dodin
