New owner of 2020 5x8' OK Schooner
Postby boots » Thu Jul 11, 2024 1:24 pm
I am new on the Teardrop forum. I am purchasing a used 2020 5x8' OK Schooner. I noticed the back hatch is sticking and it appears to slide from side to side a bit. We have had to tap it back into place(centered) but I am not sure why it keeps slipping from side to side.
I have tried contacting OK Schooners several times by phone and email with no response from them.
I am wondering if anyone has had this issue and if so how did you fix it?
Thanks a bunch!
Ruth
boots
Re: New owner of 2020 5x8' OK Schooner
Postby tony.latham » Thu Jul 11, 2024 10:59 pm
I haven't had the problem, but some folks cut a slot in the hatch side of the hinge and then set a screw into the slot from the top.
Postby tony.latham » Thu Jul 11, 2024 11:00 pm
and the sliding tracks—it
Traveljunkie99:
I think you're some kind of bot. Prove me wrong.
Postby boots » Mon Jul 15, 2024 2:52 pm
Thanks for the suggestions. We were thinking of replacing the hinge with a type of "piano hinge" so that it wouldn't slide. Tony your suggestions sounds much easier!
Cheers!
boots
Postby DJ Davis » Mon Jul 15, 2024 7:52 pm
boots,
I have this issue with my homebuilt camper. No, don't replace with a piano hinge; those aren't water-shedding as the hurricane hinges are. Better is to check/look at the ends of the hinge sections occasionally - they should be even. If not, raise the hatch and bump the side of the hatch where the hinge is hanging over too much until the hinge sections align. Cutting a slot in the hinge might lead to leaking, IMHO. Just look closer at the hinge's construction and you'll see what I mean. The hurricane hinge is designed to slide like that to "put the hatch on the trailer." Mine "moves" after bouncing down bumpy roads.
DJ
They say "What doesn't kill you makes you stronger." I've noted that if it doesn't kill you, it waits patiently for another opportunity.
DJ Davis
