norcal2 wrote:I used two batteries mounted in the floor and ran the cables underneath through the frame holes up into my power distribution box located on the left front of my V nose trailer. Everything is behind the walls and i cut the insulation out to go around the wires. I covered the battery box with a neoprene gasket and a diamondplate cover with countersunk bolts, i also ran aluminum trim on the floor between the wall and floor as well..dont have any updated pics yet showing this..
hankaye wrote:norcal2, Howdy;
Your set-up for the generators is great! However .....
you may want to re-think the exhaust pipe direction for your generators.
Up is the preferred direction as the Co (exhaust), will want to migrate that direction on
it's own. The way you have it now it's going to fill your trailer or your neighbor's with Co
and that's not such a good idea.
hank
