A True Green Conversion
Re: A True Green Conversion
Postby roadinspector » Sat Sep 28, 2013 9:09 pm
Very nice! I like you cabinet layout in the v-nose. :applause:
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby Kayakpacker » Wed Oct 02, 2013 7:24 pm
I have been working on water tank position and pump layout, it will work as plan. Tongue weight will be ok If I stay with just one battery and a little heavy if I use two batteries but any additional weight will be mostly in the back .also cut hole in roof for refegerator vent, this will be the only hole I will need to cut in the top and sides. Attached picture is of duct work and air deflector for refegerator .113003
Kayakpacker
Images: 28
Postby Kayakpacker » Sun Oct 06, 2013 6:53 pm
Got water tank frame done, water pump working , more cupboard work, drilled first set of holes for tubes to hold fishing poles, first bed is framed.[album[/album]
Kayakpacker
Images: 28
Postby Kayakpacker » Sun Oct 06, 2013 7:00 pm
Pictures of this weekend work113171113170113169
Kayakpacker
Images: 28
Postby Kayakpacker » Mon Oct 14, 2013 7:35 pm
Finished the cupboards above bunk and started cupboards in galley at the rear doors, taking my time to make sure I get everything I want like the black tubes for fishing rods. 113421113419113418
Kayakpacker
Images: 28
Postby Kayakpacker » Wed Aug 06, 2014 6:23 pm
I need some help with my water tank, I mounted the tank on the stock plywood floor and now it is sweating on the bottom causing a problem, how do I stop it from sweating?
Kayakpacker
Images: 28
Postby bc toys » Wed Aug 06, 2014 7:30 pm
insulate it bottom and sides ends and top
bc toys
Images: 42
Postby Rainier70 » Thu Aug 07, 2014 10:36 am
Also tape the insulation so that air doesn't get to the sides of the tank.
Rainier70
Images: 244
Postby Kayakpacker » Thu Aug 14, 2014 4:40 pm
Made two more tambour doors over the weekend, three more to do123272123271123271123271
Kayakpacker
Images: 28
