Idea for getting trailer into garage
Re: Idea for getting trailer into garage
Postby KAD » Mon Sep 01, 2014 10:57 am
M C Toyer wrote:I permanently mounted a pair of bogie wheels to the rear of my trailer to prevent bottoming out. They are steel and about 6 inches diameter - under $10 at Northern Tool and available fixed or swivel.
MC,
Do you happen to recall what those bogies were listed under at Northern? I can't seem to find them.
KAD
Postby lrrowe » Mon Sep 01, 2014 12:37 pm
aggie79 wrote:I made a dolly for my teardrop, not for height reasons, but for maneuverability, because of the limited space in my garage. Here's a (fuzzy) picture of it before flipping it over.
I used 500# swivel casters at all four corners. If you go this route, I'd add a middle pair for better weight distribution.
This is another interesting idea. I had a few thoughts about this approach but would need to think out how to do it given the heavy weight of the trailer.
Thanks.
Bob
lrrowe
Images: 439
Postby lrrowe » Mon Sep 01, 2014 12:41 pm
MC,
I also could not find them also using bogies or bogeys.
Bob
lrrowe
Images: 439
Postby OverTheTopCargoTrailer » Mon Sep 01, 2014 12:47 pm
BOB
for that to work you gotta remove the axel Bro.......... :x :x
I still like the 18" lower concrete :lol: :lol:
Postby M C Toyer » Mon Sep 01, 2014 9:10 pm
Here you go guys - categorized as casters. I went with the wide, solid steel wheel, non swivel, 4 inch diameter, because my boat trailer frame has u shaped cross-members with about 8 inch normal clearance. They are bolted to the lowest point and I added diagonal braces to the junction of the next cross-member and frame side rail.
Must have been on sale or clearance - pretty sure I only paid $10 each
http://www.northerntool.com/shop/tools/category_material-handling+casters+1-000-1-499-lbs.
M C Toyer
Images: 11
Postby lrrowe » Mon Sep 01, 2014 9:47 pm
Thanks MC,
For $10 each, I think I see how this could work. But if I go after the 8" ones ((I think I need that height - but will not know for sure until I receive the CT), but with today's prices, I think it will be pricey. I just have to wait and see and then decide which way to go.
Bob
lrrowe
Images: 439
