How would you raise this EZ up canopy?
Re: How would you raise this EZ up canopy?
Postby aggie79 » Fri May 22, 2015 8:00 am
ShadowFX wrote:I am not sure which model EZ UP you have, but I personally would use EZ UP Leg extensions. They come in 12 and 24 inch pairs. http://www.ezup4u.com/legExtensions.php
Note: Leg extensions are intended for professional models only. Enterprise II, Speed Shelter II, Eclipse II , Hut, Hub. The Gray colors will fit the Eclipse II aluminum models with the thicker foot pad.
If that is not your model, at least the pictures will give you an idea of how to have them made. Only one pair is required. You can attach a mount front and rear to the trailer to set and fasten the legs that are close to the trailer.
Hadn't seen these before. Thanks for posting. I have the Eclipse II aluminum.
