2016 Diamond Cargo 8.5 x 20 v-nose Conversion
Postby mrjeff » Thu Jun 09, 2016 8:53 pm
I have just begun converting the cargo trailer to a 2 motorcycle toy hauler/ camper. I have done some test loading of the bikes that combined weigh about 1500lbs. Final positioning will come once I get my built-ins done. Under counter dual voltage fridge, microwave and small bar sink in the v. Porta-pottie somewhere and an ac in the front wall. I should have somewhere between 8 and 11 ft from the cabinets to the motorcycles. I have almost finished insulating the ceiling and have started removing the plywood walls.
My first major surprise was what looked like philips screws are in fact nails and they don't come out very easy. I called the salesman, who claimed he thought they were screws, he had me call the factory and they said to get screws, you have to have the trailer built for you and then you can request screws. More to come.
I was going to post a picture of the ceiling insulation, but because it is blue and looks like all the the other blue ceilings, I will will skip the pic for now.
mrjeff
Re: 2016 Diamond Cargo 8.5 x 20 v-nose Conversion
Postby m.colley » Thu Jun 09, 2016 9:46 pm
Welcome. A 8.5x20 was one of the original sizes I contemplated buying/building before settling on my 7x16. Like you I'm building mine as a multi-purpose toy hauler & camper. Nothing as fancy as some, not as plain as others. I chose to build mine so that it would be built to mine and the wife's needs, not to some blue print that everyone else has. Good luck with your build. We like pictures so don't be afreaid to post them up.
Martin
m.colley
Images: 83
Postby McDave » Thu Jun 09, 2016 11:30 pm
Welcome mrjeff,
That's a pretty good sized trailer, You should be able to do just about anything you can imagine with that.
Have fun!
McDave
McDave
Images: 412
Postby mrjeff » Mon Jun 13, 2016 7:44 pm
Work started
trailer 375small.jpg (17.98 KiB) Viewed 2300 times
mrjeff
Postby mrjeff » Tue Jul 05, 2016 9:28 pm
First layer of 3/4 insulation on the ceiling and 3/4 furring strips almost complete. drivers side of trailer insulated and most 110volt wiring done on that side. I plan on re-installing the plywood on that side before I remove it on the passenger side. Got most of my light fixtures and wire last week and am about to start the overhead 12volt wiring, then add 1/2 inch more foam and install the luan ceiling. Need to post some pics soon.
mrjeff
Postby AnthonyH » Fri Jul 22, 2016 9:01 pm
Looking good. Getting serious about it when you get the ax out. Haha
Sent from my SM-N910V using Tapatalk
__________
Anthony
AnthonyH
Postby mrjeff » Sun Jul 24, 2016 3:04 pm
Outside lights
trailer lights 386.jpg (158.34 KiB) Viewed 1985 times
trailer lights 385.jpg (278.4 KiB) Viewed 1985 times
mrjeff
Postby m.colley » Sun Jul 24, 2016 6:44 pm
mrjeff wrote:Outside lights
Those outside spotlights are pretty popular. I added a pair at the rear of mine as well to use as loading/unloading lights. I wired mine thru a simple rocker switch at the rear door.
Martin
m.colley
Images: 83
Postby mrjeff » Sun Jul 24, 2016 8:25 pm
I am putting my switch just inside the side door. They are going to be used as backup lights also.
mrjeff
Postby McDave » Wed Jul 27, 2016 1:34 pm
+1 on the back up lights. flboy had a nice run down on the wiring specifics in his build journal. Check it out, he's a pretty smart cookie.
McDave
McDave
Images: 412
