Outside shower
Outside shower
Postby mrwall1 » Sat Mar 04, 2017 9:23 pm
I was looking through amazon, I see there are several outside shower units... which brand did you go with? Also I am not sure if I should put the tank waterfill and city water hook up together... My tank will be about 3 feet away from the pump... so i was thinking of putting in separate water-fills... one above the tank for tank fill and one above the pump, so it will be easier access to the valves.... Oh these hard decisions !!
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Re: Outside shower
Postby daveesl77 » Sun Mar 05, 2017 8:02 am
We have a Triton 5L, on demand water heater. Our water system has both external and internal supply hookups. I just used brass quick connects to make changing from one supply to the other easy, but could have done it with Y valve setup. This is our second 5L and we love these.
dave
daveesl77
Images: 273
Re: Outside shower
Postby mrwall1 » Sun Mar 05, 2017 8:32 am
daveesl77 wrote:We have a Triton 5L, on demand water heater. Our water system has both external and internal supply hookups. I just used brass quick connects to make changing from one supply to the other easy, but could have done it with Y valve setup. This is our second 5L and we love these.
dave
Thanks Dave, that is what we are buying for our hot water, I didn't realize it came with a shower... That will save me from cutting a hole in the side of the trailer!
Mike
mrwall1
Re: Outside shower
Postby Shadow Catcher » Sun Mar 05, 2017 9:14 pm
I imported a Bulfinch shower point http://bullfinch-gas.co.uk/outdoor-utility-points/external-shower-point-detail
All of the external RV type shower I found were big and cludgy. I also have one of their gas points.
Re: Outside shower
Postby flboy » Sun Mar 12, 2017 8:43 pm
This is what I used. It is well built and the door is very solid. I've not actually used it other than to test it out.
https://www.amazon.com/gp/product/B002U ... UTF8&psc=1
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
