Iconfabul8 wrote:I personally don't think you need guides and rails.
John61CT wrote:Issue isn't just swinging while raising/lowering, but also in use, not a platform for corpses, live people do move around.
I'd prefer to not need anything fixed to the walls, also prefer to be able to stop at any height.
For safety, just need to make sure the wire rope and its attachment point is properly load bearing.
Two lengths of wire (or rope, not load-bearing) fixed to the ceiling and floor, threaded through small vertical tubes mounted catty corner to the outside of the platform edge, could more flexibly act as a horizontal guide/restraint without needing to fix anything to walls.
aggie79 wrote:In my example, the casters were for location only.
aggie79 wrote:There would also need to be positive stops for the raised position and lowered position.
John61CT wrote:The weight while raising and lowering is not nearly as much as when in use.
If the ceiling doesn't have strong support beams, you couldn't walk on the roof or install solar panels or a rack, maybe like a foamie?
Then you would need to construct a frame so that all the weight gets borne by the floor.
