6 x 10 trailer camperizing progressing
Postby 41willys » Tue Apr 28, 2009 11:13 pm
I have installed the side paneling
41willys
Images: 44
Postby 41willys » Tue Apr 28, 2009 11:21 pm
other side
rear view
window side
fold away seat support "out"
fold away seat support back in place.
seat base in place
[img]http://www.tnttt.com/gallery/image.php?image_id=49492][/img]
power panel installed and wired up.
41willys
Images: 44
Postby 41willys » Tue Apr 28, 2009 11:38 pm
shelving now in cabnets
41willys
Images: 44
Postby hunter535 » Wed Apr 29, 2009 5:26 am
41 willys,
That is looking really sweet :thumbsup:
I like the seats and the cabinets in front. What is your wall sheathing? That is nice looking as well!
hunter535
Images: 47
Postby High Desert » Wed Apr 29, 2009 5:46 am
hey, that's looking real nice. You're doing some great work, look forward to seeing more.
Shaun
High Desert
Images: 27
Postby 41willys » Wed Apr 29, 2009 7:47 am
Thanks for the comments, the wall covering is a 4 x8 sheet of paneling i found at a local hardware store that is covered with a textured paper that is mostly white with splashes of blue/gray and a little red in it. I used contactors glue in a tube to put it on with, would not do that again the glue is great for 100% contact bonding but this was far from that. Due to the wall being curved I could not force the sheet against the wall everyware. I would use some kind of silicone / glue next time. it has worked but not 100% happy.
The seats have been a healthy debate with the wife! so far Im winning which means the seat cushons will be attached to the plywood base. two base seats and two back supports this will allow for me to rotate the pieces into a bed accross the flip out support.
41willys
Images: 44
Postby drcurran » Wed Apr 29, 2009 8:36 pm
The seats have been a healthy debate with the wife! so far I'm winning
Thanks 41Willys - I like an optimist no matter how wrong he is :) But I must tell you the Cargo Trailer looks great. If I ever really get going on mind I hope I can do as nice a job as you have.
Dan
"I'm not as good as I once was, but I'm as good once as I ever was."
TK
drcurran
Images: 20
