Installation of windows in a enclosed trailer
Postby tdg » Sun Sep 13, 2009 11:31 am
I will be adding windows to my 5x8. I will be using 24x14 typical two piece windows. The trailer has the 16 inch on center z metal for studs. I will need to cut one stud on each side. I plan to either bolt or have my brother in law weld in an upper and lower reinforcement pieces to replace the stud.
My question is do the reenforcement pieces need positioned so the window rest on them?
tdg
Postby Prem » Sun Sep 13, 2009 1:29 pm
No. The new cross pieces will just carry the load in place of the upright you cut out.
Prem
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby edcasey » Sun Sep 13, 2009 9:30 pm
Most window manufacturers recommend 1/8 inch clearance between window frame and the wall opening. In other words, the window rough opening should be 1/4 inch wider and 1/4 inch taller than the window.
edcasey
Postby Prem » Sun Sep 13, 2009 10:12 pm
:yes: What edcasey said. (Same for roof vent cutouts.)
And remember to insulate or caulk so that dissimilar metals are not touching. Electrolysis.
(Ah, an additional benefit of an all aluminum trailer.)
Prem
My goal...
Prem
Images: 144
Postby tdg » Mon Sep 14, 2009 6:05 pm
Thanks for the Help guys. This will really get my camper on its way, after the windows, insulation, pretty simple wiring and of course AC.
tdg
Postby Prem » Tue Sep 15, 2009 12:10 am
tdg,
Cool! Post photos asap.
Prem
My goal...
Prem
Images: 144
Postby hunter535 » Tue Sep 15, 2009 9:42 pm
Prem wrote:tdg,
Prem
Definitely post some :pictures:
hunter535
Images: 47
Postby michiganflipper » Sun Jan 10, 2010 7:22 pm
Here is a web site for instaling windows
http://www.motionwindows.com/installation-guide.php
michiganflipper
