theycallmemorris wrote:I have come across several "squirrel cage" blower fans that may work out perfect, but need to make it back home to see the generator for what sort of clearances I have. With one of them, the generator noise would be even more self contained because of the way the air is vented through them without just having a large hole for a fan.
Did anyone take a look at those AC adapter links I put up? Do you think they would hold up? A 110V blower fan would work great if it would fit, but the ATV fans sure are reliable.
d30gaijin wrote:theycallmemorris wrote:
Go to an automotive wrecking yard and look for a small automotive electric fan from a radiator (they come in all number of sizes) they are waterproof, move plenty of air, and then get a small 110v ac to 12v dc converter like you showed in the link you put up. That should keep the price fairly low.
Don
